[snappyHexMesh] multi region mesh using snappyHexMesh
Old   July 8, 2010, 10:14
Default multi region mesh using snappyHexMesh
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I want to simulate a flow through a pipe where two regions of porous
medium are by using porousSimpleFoam solver.
I have only stl data of solid regions (wall of pipe and porous medium) and
don't fluid regions.
Is it possible to generate multi region mesh (like snappyMultiRegionHeater
tutorial) using snappyHexMesh utility without stl files of fluid regions and
the region between wall of pipe and blockMesh boundaryies?
If so, could you tell me the way to do it?
Thanks in advance for your help.
fumiya is offline   Reply With Quote
Old   September 19, 2016, 11:44
cfdsolver1 is on a distinguished road
Dear Fumiya,
I am also having same problem. Did you find a solution for your problem?
Thanks.
Originally Posted by fumiya View Post
cfdsolver1 is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] Error with a turbine mesh with SnappyHexMesh DOliveira OpenFOAM Meshing & Mesh Conversion 1 July 16, 2015 08:02
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 19:54
[snappyHexMesh] multi region with snappyHexMesh vikthor OpenFOAM Meshing & Mesh Conversion 0 August 24, 2012 03:47
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
