[snappyHexMesh] snappyHexMesh
Old   October 14, 2010, 03:28
Default snappyHexMesh
RalphS is on a distinguished road
There are some news about the difficult with "sharp" edges?
For example, I have a cylinder: inlet, outlet, wall.
How can I improve the behaviour of sHM at the end of the cylinder?
RalphS is offline   Reply With Quote
Old   October 14, 2010, 04:30
Vincent RIVOLA
vinz is on a distinguished road
Look for snapEdge on the forum.
Depending on the complexity of your mesh it does a pretty good job!
vinz is offline   Reply With Quote
Old   October 14, 2010, 05:57
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Hi, RalphS,
For the cylinder case, I will use setSet to "collect" the cells that fall inside the region you want. Then, do a subsetMesh to cut out the cells you do not want. You should get a pretty good mesh at the cylinder ends.
You have to repeat this twice, one for the inlet and one for the outlet.
Pei
phsieh2005 is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
