[snappyHexMesh] underdeterminedCells
Old   January 6, 2011, 05:14
Default underdeterminedCells
Robert Ong
rob3rt 0ng is on a distinguished road
Dear All,
I keep encounter the underdeterminedCells problem and really appreciate if you can help me with this.
Here is the checkMesh output at SHM -latestTime folder:
Time = 0.003
Mesh stats
faces: 1536336
internal faces: 1358718
cells: 470885
boundary patches: 9
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 330057
prisms: 32100
wedges: 0
pyramids: 0
tet wedges: 1841
tetrahedra: 18
polyhedra: 106869
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology Bounding box
inlet 277 346 ok (non-closed singly connected) (-4.72261 -2.45232 -10.0353) (-4.59171 6.63503 1.74641)
patient_Outlet7 280 469 ok (non-closed singly connected) (-10.1504 -55.2556 -112.911) (-7.43396 -52.0717 -110.325)
patient_Outlet6 96 148 ok (non-closed singly connected) (-68.4308 11.8798 -164.197) (-67.262 13.2621 -162.795)
patient_Outlet5 331 436 ok (non-closed singly connected) (-103.498 1.02312 -130.839) (-100.359 2.27901 -128.027)
patient_Outlet4 22 38 ok (non-closed singly connected) (-103.626 -11.5322 -104.36) (-102.943 -11.0494 -103.605)
patient_Outlet3 174 261 ok (non-closed singly connected) (-75.9318 4.84919 -20.7391) (-74.3726 7.82684 -18.8701)
patient_Outlet2 72 132 ok (non-closed singly connected) (-90.9039 76.1677 -53.2535) (-89.7788 77.6239 -51.9731)
patient_Outlet1 164 223 ok (non-closed singly connected) (-64.8448 129.496 -98.3191) (-61.9272 130.703 -97.6571)
patient_Patient2 176202 214951 multiply connected (shared edge) (-103.626 -64.5097 -166.667) (-4.59171 130.703 5.02298)
<<Writing 4 conflicting points to set nonManifoldPoints
Checking geometry...
Overall domain bounding box (-103.626 -64.5097 -166.667) (-4.59171 130.703 5.02298)
Mesh (non-empty, non-wedge) directions (1 1 1)
Boundary openness (-3.86952e-17 1.71227e-16 3.76657e-17) OK.
Max cell openness = 3.13562e-16 OK.
Max aspect ratio = 7.75377 OK.
Minumum face area = 0.00112404. Maximum face area = 7.71469. Face area magnitudes OK.
Min volume = 0.000432306. Max volume = 11.2818. Total volume = 20464.4. Cell volumes OK.
Mesh non-orthogonality Max: 64.8085 average: 14.498
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 3.78346 OK.
Min/max edge length = 0.0316528 1.5 OK.
*There are 4325 faces with concave angles between consecutive edges. Max concave angle = 78.5315 degrees.
<<Writing 4325 faces with concave angles to set concaveFaces
Face flatness (1 = flat, 0 = butterfly) : average = 0.995389 min = 0.115482
*There are 21 faces with ratio between projected and actual area < 0.8
Minimum ratio (minimum flatness, maximum warpage) = 0.115482
<<Writing 21 warped faces to set warpedFaces
Cell determinant (wellposedness) : minimum: 0 average: 14.9775
***Cells with small determinant found, number of cells: 7
<<Writing 7 under-determined cells to set underdeterminedCells
Failed 1 mesh checks.
End
The SHM setting:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
patient.stl
type triSurfaceMesh;
name patient;
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// While refining maximum number of cells per processor. This is basically
// the number of cells that fit on a processor. If you choose this too small
// it will do just more refinement iterations to obtain a similar mesh.
maxLocalCells 1000000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 2000000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 10;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
// file "someLine.eMesh";
// level 2;
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
patient
// Surface-wise min and max refinement level
level (3 4);
// Resolve sharp angles
resolveFeatureAngle 30;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
// refinementBox
// mode inside;
// levels ((1E15 4));
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (-6 0 0);
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 3;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 4.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 30;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 5;
// Settings for the layer addition.
addLayersControls
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
// Expansion factor for layer mesh
expansionRatio 1.0;
//- Wanted thickness of final added cell layer. If multiple layers
// is the
// thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
finalLayerThickness 0.3;
//- Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.1;
//- If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
nGrow 1;
// Advanced settings
//- When not to extrude surface. 0 is flat surface, 90 is when two faces
// make straight angle.
featureAngle 30;
nRelaxIter 3;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 10;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
// Angle used to pick up medial axis points
minMedianAxisAngle 130;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations
nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65;
//- Max skewness allowed. Set to <0 to disable.
maxBoundarySkewness 20;
maxInternalSkewness 4;
//- Max concaveness allowed. Is angle (in degrees) below which concavity
// is allowed. 0 is straight face, <0 would be convex face.
// Set to 180 to disable.
maxConcave 80;
//- Minimum projected area v.s. actual area. Set to -1 to disable.
minFlatness 0.5;
//- Minimum pyramid volume. Is absolute volume of cell pyramid.
// Set to very negative number (e.g. -1E30) to disable.
minVol 1e-13;
//- Minimum face area. Set to <0 to disable.
minArea -1;
//- Minimum face twist. Set to <-1 to disable. dot product of face normal
//- and face centre triangles normal
minTwist 0.02;
//- minimum normalised cell determinant
//- 1 = hex, <= 0 = folded or flattened illegal cell
minDeterminant 0.001;
//- minFaceWeight (0 -> 0.5)
minFaceWeight 0.02;
//- minVolRatio (0 -> 1)
minVolRatio 0.01;
//must be >0 for Fluent compatibility
minTriangleTwist -1;
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
Here is what the underdeterminedCells and mesh in paraview looks like
Thanks for your time and attention.
Kind Regards,
Robert
rob3rt 0ng is offline   Reply With Quote
Old   January 17, 2011, 14:24
bruce
bruce is on a distinguished road
Hi
Do you add layers? I don't see this in the "addLayersControls"
If you added, It seems you might have bad mesh after layer addition. Have you done checkMesh for snapped mesh ( time = 2 ) ? Do you still have concave, warped faces ? if that is the case try to tight your quality settings , of course that will make approximations to real cad !
na
bruce is offline   Reply With Quote
Old   January 17, 2011, 22:12
Robert Ong
Hi Bruce,
Thanks for the reply.
I didn't add any layers.
Below is the checkMesh output:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 1043700
internal faces: 1014300
cells: 343000
boundary patches: 1
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 343000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Point usage OK.
Face vertices OK.
inlet 29400 29402 ok (closed singly connected)
Overall domain bounding box (-107 -70 -170) (-4.5 140 10)
Boundary openness (-1.90981e-16 -1.51374e-17 5.27562e-15) OK.
Max cell openness = 1.20272e-16 OK.
Max aspect ratio = 2.08926 OK.
Minumum face area = 3.69236. Maximum face area = 7.71476. Face area magnitudes OK.
Min volume = 11.0771. Max volume = 11.2943. Total volume = 3.8367e+06. Cell volumes OK.
Mesh non-orthogonality Max: 0.632047 average: 0.299557
Face pyramids OK.
Max skewness = 0.0197593 OK.
Mesh OK.
--> FOAM Warning :
From function polyMesh::readUpdateState polyMesh::readUpdate()
in file meshes/polyMesh/polyMeshIO.C at line 205
Number of patches has changed. This may have unexpected consequences. Proceed with care.
Time = 0.001
Mesh stats
faces: 1517757
internal faces: 1240017
cells: 430694
boundary patches: 9
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 388746
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 41948
Point usage OK.
Face vertices OK.
inlet 277 374 ok (non-closed singly connected)
patient_Outlet7 536 623 ok (non-closed singly connected)
patient_Outlet6 159 189 ok (non-closed singly connected)
patient_Outlet5 503 586 ok (non-closed singly connected)
patient_Outlet4 34 50 ok (non-closed singly connected)
patient_Outlet3 283 341 ok (non-closed singly connected)
patient_Outlet2 150 181 ok (non-closed singly connected)
patient_Outlet1 193 237 ok (non-closed singly connected)
patient_Patient2 275605 277293 multiply connected (shared edge)
Overall domain bounding box (-103.565 -64.375 -166.625) (-4.59286 130.625 5.17859)
Boundary openness (8.42463e-17 -1.9502e-16 -1.76402e-15) OK.
Max cell openness = 2.11325e-16 OK.
Max aspect ratio = 2.0903 OK.
Minumum face area = 0.014352. Maximum face area = 7.71469. Face area magnitudes OK.
Min volume = 0.002691. Max volume = 11.2818. Total volume = 20490.5. Cell volumes OK.
Mesh non-orthogonality Max: 42.6624 average: 11.4072
Face pyramids OK.
Max skewness = 1.01276 OK.
Mesh OK.
Time = 0.002
Mesh stats
faces: 1517757
cells: 430694
boundary patches: 9
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 388746
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 41948
Point usage OK.
Face vertices OK.
patient_Outlet7 526 608 ok (non-closed singly connected)
patient_Outlet6 159 188 ok (non-closed singly connected)
patient_Outlet5 468 545 ok (non-closed singly connected)
patient_Outlet4 28 42 ok (non-closed singly connected)
patient_Outlet3 296 355 ok (non-closed singly connected)
patient_Outlet2 146 172 ok (non-closed singly connected)
patient_Outlet1 200 243 ok (non-closed singly connected)
patient_Patient2 275640 277311 multiply connected (shared edge)
Overall domain bounding box (-103.626 -64.5097 -166.667) (-4.59171 130.703 5.02362)
Boundary openness (-3.67117e-16 5.83083e-16 4.88723e-16) OK.
Max cell openness = 3.15439e-16 OK.
Max aspect ratio = 7.6818 OK.
Min volume = 0.000523331. Max volume = 11.2818. Total volume = 20478.5. Cell volumes OK.
Mesh non-orthogonality Max: 64.1816 average: 14.1079
Face pyramids OK.
Max skewness = 3.82228 OK.
Mesh OK.
Time = 0.003
Mesh stats
faces: 1517673
cells: 430694
boundary patches: 9
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 388682
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 42012
Point usage OK.
Face vertices OK.
patient_Outlet7 505 605 ok (non-closed singly connected)
patient_Outlet6 154 187 ok (non-closed singly connected)
patient_Outlet5 444 541 ok (non-closed singly connected)
patient_Outlet3 281 354 ok (non-closed singly connected)
patient_Outlet2 134 168 ok (non-closed singly connected)
patient_Outlet1 193 241 ok (non-closed singly connected)
Face pyramids OK.
Mesh OK.
End
I think I've played around with the qualityControl settings before, but this setting gave me a slightly better checkMesh output.
Kind Regards,
Robert
[snappyHexMesh] snappyHexMesh - backward facing step hcl734 OpenFOAM Meshing & Mesh Conversion 4 November 20, 2015 09:57
No convergence because of underdeterminedCells? Tobi-R OpenFOAM 4 September 13, 2011 05:02
