[mesh manipulation] Convert a mesh from 3D to 2D
Old   March 31, 2011, 11:54
Default Convert a mesh from 3D to 2D
Grim
Opxah is on a distinguished road
I have created a 3 dimensional polyhedral mesh for openFoam. This was done using gmsh, gmshToFoam, and polyDualMesh.
Now I want to pick one of the faces of the cube and use this to create a two dimensional mesh. For openFoam this means two identical 2D meshes that are seperated in the 3rd dimension.
Is there an easy way to do this? (Or a hard way, if there is no easy way)
Opxah is offline   Reply With Quote
convert, mesh, polydualmesh
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ANSYS Meshing] Convert a Nastran mesh (.bdf) to Fluent mesh (.msh) dynlevirus ANSYS Meshing & Geometry 1 August 27, 2012 04:06
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
