[Gmsh] A basic Gmsh question: 1D transfinite
Old   May 10, 2011, 10:58
Default A basic Gmsh question: 1D transfinite
Matt
the_phew is on a distinguished road
My Pointwise license has lapsed, and I need to get by with Gmsh for the near term. The code seems to be pretty nice, but I have a very fundamental issue that I was hoping to get help on:
I have a line, and I want to specify its dimension and spacing at both ends. In Pointwise, I would simply dimension the connector, specify the DeltaS at each end, then choose a distribution (tanh seems to always work well). In Gmsh, only two distributions are available, "Progression" and "Bump", but for both of these, the spacings at both ends are dependent variables (dependent on the Progression Parameter and Dimension). I want the independent variables to be the spacings at each end and the dimension. Is this possible?
Thanks
P.S.-Related question; how do you find out the dimension of a line/curve generated by the "regular" (non-transfinite) 1-D algorithm? I would like the dimension to display when I mouse over the entity, but it only tells me the index of the line and its endpoints.
the_phew is offline   Reply With Quote
[Gmsh] "Perhaps you have not exported the 3D elements?" j_moulton OpenFOAM Meshing & Mesh Conversion 14 October 6, 2022 21:58
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 05:46
GMSH - Very strange effect - Mesh elements deleted when saving Araist Mesh Generation & Pre-Processing 3 July 15, 2015 06:03
Basic question forsumit OpenFOAM 0 April 7, 2010 10:46
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
