[snappyHexMesh] How to use faceList instead of faceCompactList
Like Tree8Likes
  • 1 Post By BTom
  • 7 Post By aliqasemi
Old   October 6, 2011, 04:47
Post How to use faceList instead of faceCompactList
BTom is on a distinguished road
Hi!
The new snappyHexMesh includes feature edge handling which may significantly improve the quality of your mesh.
http://www.openfoam.com/news/snappyH...ature-edge.php
Now my problem is that I need to perform my calculations on an older OpenFoam-Version 1.7.1 where this feature is not supported, yet. So I tried to create the mesh with version 2.0.0 and then use the mesh in Version 1.7.1. Unfortunately the new version 2.0.0 stores faces in a compact list "faceCompactList" which is not recognized in 1.7.1 where only "faceList" is known.
So my question is:
Does anybody know, how to deactivate the usage of faceCompactList and use faceList instead, so I can use the mesh in the older version 1.7.1???
Or maybe you have another idea to overcome this problem....
Thanks a lot
BTom
amuzeshi likes this.
BTom is offline   Reply With Quote
Old   February 14, 2012, 16:57
Default utility to convert from compactFaceList to faceList
Ali Q Raeini
aliqasemi is on a distinguished road
It is easy to write the code, see the attached, if you havn't done this already
aliqasemi is offline   Reply With Quote
Old   August 4, 2021, 17:00
Alejandra Hernández Escobar
ajelahe74 is on a distinguished road
Hello! I'm very new to foam-extended. I'm trying to work there with a mesh I did in OpenFOAM v8. I see the .tar folder but I'm not sure how to use it, how to set it up in foam-extend 4.0 to get the utility to work.
Any help would be appreciated.
ajelahe74 is offline   Reply With Quote
Old   April 12, 2022, 22:02
Juan Salazar
saladbowl is on a distinguished road
Make sure your OpenFOAM environment variables are set. Download the tar.gz file and copy it to $WM_PROJECT_USER_DIR. Untar the file and edit Make/files, changing
EXE = $(I_DIR)/bin/compactFaceToFace
to
EXE = $(FOAM_USER_APPBIN)/compactFaceToFace
Run wmake in the compactFaceToFace folder. It may be necessary to add additional libraries to the Make/options file. In my case it was.
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools
After compilation, you should be able to run the app compactFaceToFace from within the desired case directory.
saladbowl is offline   Reply With Quote
Old   January 31, 2023, 09:56
Neb
Neb is on a distinguished road
Hi, I have the same problem on foam-extend 4.1 e solids4Foam 2.0. When I go to run make I get these errors and it doesn't compile. Can you help me?
Making dependency list for source file compactFaceToFace.C
SOURCE=compactFaceToFace.C ; g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/morgana2021/foam/foam-extend-4.1/src/finiteVolume/lnInclude -I/home/morgana2021/foam/foam-extend-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/morgana2021/foam/foam-extend-4.1/src/foam/lnInclude -I/home/morgana2021/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/compactFaceToFace.o
compactFaceToFace.C: In function ‘int main(int, char**)’:
compactFaceToFace.C:67:6: error: ‘faceCompactIOList’ was not declared in this scope
faceCompactIOList facesCompact
compactFaceToFace.C:95:9: error: ‘facesCompact’ was not declared in this scope
facesCompact
make[1]: *** [compactFaceToFace.dep:730: Make/linux64GccDPInt32Opt/compactFaceToFace.o] Error 1
make: *** [makefile:9: wmake] Error 2
Neb is offline   Reply With Quote
facecompactlist, facelist, feature edge handling
Creating a pointMesh with pointField and faceList Thilo OpenFOAM Programming & Development 0 July 19, 2012 06:36
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
