[mesh manipulation] refineMesh globalCoeffs questions
Old   February 17, 2012, 10:19
Default refineMesh globalCoeffs questions
ic3wall is on a distinguished road
Does the xyz coordinates systems in refineMeshDict correspond to the x1x2x3 coordinate system that we define in blockMesh ?
My mesh is a box containing only hexes, x1x2x3 coords are defined by the order of my vertices in blockMeshDict. If I want to refine with the same coordinate system as defined in blockMeshDict, do I need to change tan1(1 0 0) and tan2(0 1 0) ?
ic3wall is offline   Reply With Quote
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 13:44
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 05:16
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 11:20
checkMesh Errors after refineMesh mgdenno OpenFOAM 0 July 30, 2012 21:39
