[snappyHexMesh] Cannot get my geometry file inside the blockMesh
Old   March 1, 2012, 16:23
Default Cannot get my geometry file inside the blockMesh
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi all;
I'm back to OF after a year or so and I'm trying to mesh a simple circular cylinder. I started from the motorbike tutorial and… my cylinder is not within my domain once snappyHexMesh has done his job…
I'm sure is something stupid I'm missing here but yet I can't figure it out…
Could anybody of you guys take a look at my files here enclosed?
Thank you!
lovecraft22 is offline   Reply With Quote
Old   March 2, 2012, 13:38
lore
Seems like the geometry is not seen at all…
Old   March 3, 2012, 07:26
lore
I started again from the motorbike tutorial and I replaced the motorbike geometry with my cylinder without changing any name and yet… no geometry inside the domain… so it is not a setup issue, I think it's related to my stl/obj geometry file… but how? I really can't figure it out…
Any help would be really appreciated…
Old   March 3, 2012, 09:45
Retired Super Moderator
Bruno Santos
Hi Lore,
Read this thread: http://www.cfd-online.com/Forums/ope...tml#post346810
Well, you can skip to post #8, where you should find a test case similar to yours and on post #9 you have my description of what was wrong on that case.
If you still have problems after analyzing that case and analysis, please detail a bit your questions
Best regards,
Bruno
Old   March 3, 2012, 10:17
lore
Thank you Bruno.
I think all the points you outlined in that discussion were already ok.
Please have a look at these pictures where you can see:
Pic 1: domain outline (white), cylinder geometry (yellow), point inside the domain (red sphere);
Pic 2: slice through the domain: I have the mesh where it should not be…
So, so summarize: the geometry is within my domain and the point in the domain is where it should be, and yet, no cylinder in the mesh…
Thanks again for your time.
Old   March 3, 2012, 10:40
Bruno Santos
Hi Lore,
On the "geometry" section, you specify the kinds of geometries that will be part of the mesh generation process; but then on the respective following sections, you have to specify what kinds of refinement you need on each, so sHM knows what should be done with each one. It's probably made to work this way to avoid the software making assumptions, which can lead to problems in certain cases!
Therefore, you're missing at least this:
    refinementSurfaces
        cilindro.stl
            // Surface-wise min and max refinement level
            level (0 0);
Notice that no additional refinement is requested, but it indicates how the geometry should be used.
Best regards,
Bruno
Old   March 3, 2012, 11:22
lore
Thank you Bruno! That was the issue!
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
