[Gmsh] How to get Gmsh hex mesh for "2-D" simulation in OF?
Old   August 8, 2012, 13:01
Default How to get Gmsh hex mesh for "2-D" simulation in OF?
jam
Alain Martin
jam is on a distinguished road
I am having difficulties trying to do a mesh for a good 2-D OF solution from Gmsh.
Because my domain is not so simple, I cannot use blockMesh. The next best is Gmsh, IMHO. To get an OF 2-D mesh, I used:
Extrude { x,x,x}{
Surface {xxx} ; Layers{1,1};
Recombine;
I just learned last week that if I recombine a transfinite surface before the extrusion, I can get quad elements which solved much better than the prism elements.
But I would like to use the unstructured mesh and extrude as above but create hex elements. This doesn't seem possible because the third direction is also divided which give 2 Layers and therefore is not considered as a 2-D problem anymore. As a 3-D problem it is solvable but it takes a very long time with my setup.
My question is : is it possible to remove the second mesh layer after the meshing is done or is it possible to prevent the third dimension to be divided before meshing?
jam is offline   Reply With Quote
Fatal overflow error, singularity, due to local mesh form? Thomasbr CFX 7 July 8, 2016 09:57
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[blockMesh] Blockmesh error - 2D scramjet ishaninair OpenFOAM Meshing & Mesh Conversion 7 March 18, 2011 00:14
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
