[snappyHexMesh] SnappyHexMesh AddLayer Control
Like Tree1Likes
Old   May 14, 2013, 10:14
Mehdi GHOZALI
Dadou is on a distinguished road
Originally Posted by A.Wendy View Post
hi,
I've never worked with k-epsilon. sorry. but have you turned off the turbulence and tried a laminar simulation?
Andy
no problem, the thing is that I need turbulence for this case. But anyway I'll try something
Thanks for your help
Regards
Mehdi
Dadou is offline   Reply With Quote
Old   May 14, 2013, 14:30
Andreas Wendy
A.Wendy is on a distinguished road
Originally Posted by Dadou View Post
Regards
Mehdi
hi mehdi,
not for the whole time. only to check if the boundary conditions are ok. so use laminar model first check if the calculation works. if not modify the case until the laminar case works. then try to use the tubulence model
best wishes
andy
A.Wendy is offline   Reply With Quote
Old   May 15, 2013, 03:14
Mehdi GHOZALI
hi mehdi,
best wishes
andy
Okay I will try it today
Old   May 17, 2013, 01:45
Andreas Wendy
hi,
did the laminar computation worked?
Andy
Old   May 17, 2013, 03:52
Mehdi GHOZALI
hi,
Andy
hi,
Nop it doesn't work and I know why, I have a problem with the thickness of the boundary layer (y+) it has to be around 30 and I have 20000 (yeah I'm way to far) so I have to refine the mesh in the snappyHexMesh but the problem is that when I turn on the snap and lunch snappyHexMesh I don't have the smooth part on paraview. do you know what do I have to change?
I atteched my blockMesh and snappyHexMesh (be carefull it takes time to do it cause I have more the 5 millions cells)
Thank you
Mehdi
Old   May 28, 2014, 22:21
J.-H. Wang
f0208secretx is on a distinguished road
Hello all,
I've been playing with the addLayer control and can seem to make it work. The geometry I have is similar to the original post, a big cube with a small cube subtracted inside.
The snappyHexMeshDict of mine looks like
addLayersControls
    layers
        "cube.*"
            nSurfaceLayers 3;
    relativeSizes true;
    expansionRatio 1.1;
    finalLayerThickness 0.3;
    minThickness 0.1;
    nGrow 0;
    featureAngle 30;
    slipFeatureAngle 30;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
    nRelaxedIter 20;
    nLayerIter 50;
Right now I am really confused about the part shown in red, the name of the layer should be the patch name defined previously? I think it should be the name labeled in blue, correct?
geometry
    cube.stl
        type triSurfaceMesh;
        name cube;
    box10x10x10
        type searchableBox;
        min (-5 -5 -5);
        max ( 5  5  5);
But I cannot get it to work; been dancing around this problem for some time already... There is no error shown in my log file. I attached the complete dictionary & log file for your reference. Thanks a lot for any advise.
JHW
f0208secretx is offline   Reply With Quote
Old   May 29, 2014, 00:46
Mehdi GHOZALI
Hi JHW,
I am a bit busy right now, but I will look it up this week end and let you know what's wrong (or maybe nothing wrong).
Hope by that time you will have an answer if not I will try my best to respond soon.
Regards,
Dadou
Old   May 29, 2014, 09:38
J.-H. Wang
Thanks for the offer. Is my understanding about the name of the patch correct? The blue font and the red font should match?
JHW
Old   May 30, 2014, 05:32
Eloïse
Eloise is on a distinguished road
Hi JHW,
Look at you boundary file after mesh generation. You'll find there the name of the existing patches in your mesh. Re-use those names to insert your layers.
I hope that helps,
Regards,
Eloïse
f0208secretx likes this.
Eloise is offline   Reply With Quote
[snappyHexMesh] Run snappyHexMesh steps (castellated, snap, addlayer) separately Glc OpenFOAM Meshing & Mesh Conversion 6 October 8, 2021 02:50
[snappyHexMesh] snappyHexMesh small pyramid volume control taeyounk OpenFOAM Meshing & Mesh Conversion 2 July 13, 2017 12:07
[snappyHexMesh] bumpy on the surface of 3D wing in addlayer step with snappyHexMesh Kim sung hwan OpenFOAM Meshing & Mesh Conversion 2 April 21, 2015 03:51
[snappyHexMesh] Mesh quality control in snappyHexMesh - OpenFOAM 2.3.0 arapuraz OpenFOAM Meshing & Mesh Conversion 1 August 12, 2014 04:17
[snappyHexMesh] AddLayer Control MAV OpenFOAM Meshing & Mesh Conversion 0 April 11, 2012 05:51
