[OpenFOAM] paraFoam - "called for invalid fileName NewFolder" |
June 27, 2013, 06:47 |
Rep Power: 12 |
I followed what was explained in this link: http://www.openfoam.org/docs/user/ca...#x5-110002.1.2 i.e. 2.1.2 Viewing the mesh, where reference was made to paraFoam. When the ParaView window was opened, I mistakenly closed the 'pipeline browser' & 'Object Inspector'. In the course of trying to play around with it to see if I can bring them up again, this was displayed: fileName::stripInvalid() called for invalid fileName NewFolder For debug level (= 2) > 1 this is considered fatal Aborted (core dumped) This made the ParaView window not to come up again. Please kindly advise on what to do. Thank you. |
June 27, 2013, 10:32 |
Mohsen KiaMansouri
Dear Greatness
That's because you created a NewFolder inside your case. move it to a different folder or delete it then run paraFoam again
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.” |
June 27, 2013, 17:54 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Actually, the problem is that the real name of the folder is "New Folder" and OpenFOAM does not like spaces in names of files and folders. @Greatness: If you rename the folder from "New Folder" to "NewFolder", the problem no longer occurs. Best regards, Bruno
July 1, 2016, 08:50 |
Navid
Hello everyone!
Thank you very much for you're valuable suggestions. Another reason of this error might be that after running you're case, you cut the folder into other one. For my own case, after moving back the folder, paraFoam was loaded with no error. |
December 21, 2019, 04:51 |
#5 | |
reza moradi
thanks a lot |
Star 13.06.012 mismatched types in mpi error server reset | cdimock72 | STAR-CCM+ | 0 | April 14, 2019 11:19 |
Star ccm+ non newtonian error | miyendisbey | STAR-CCM+ | 1 | May 12, 2017 15:10 |
Heat Transfer Error Message | darsonli | STAR-CCM+ | 0 | September 22, 2014 21:00 |
Error VolumeFractionLevel1 | savr1484 | STAR-CCM+ | 3 | February 4, 2014 00:55 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 05:49 |
