[OpenFOAM] Cannot track LAgrangian particles
Like Tree2Likes
  • 2 Post By Eranho
Old   September 26, 2014, 06:19
Default Cannot track LAgrangian particles
Na
Eranho is on a distinguished road
Hello
I have a problem to visualize Lagrangian particles at aachenBomb tutorial. The case executes correctly and I can see temperature and pressure field etc. When I run the 'foamToVTK' it makes the VTK directory.
But when I open the Paraview and open the files at VTK directory according this tutorial (page 8):
http://www.tfd.chalmers.se/~hani/kur...ered_NL_HN.pdf
and when I try to create glyphs for claud and press 'apply', the Paraview crashes down every time. Is this a known problem or do I do something wrong?
I'm using OpenFOAM 2.1.1 and Paraview 3.12.0
Thanks, Eranho
Eranho is offline   Reply With Quote
Old   September 28, 2014, 14:40
Retired Super Moderator
Bruno Santos
Greetings Eranho,
I've done a really quick test just now and I had no problems by following these steps:
  1. Used Ubuntu 12.04 and OpenFOAM 2.1.1.
  2. Used a clean copy of the original tutorial "lagrangian/sprayFoam/aachenBomb".
  3. Ran:
    blockMesh
    sprayFoam
    foamToVTK
    paraview
    Honestly I only allows the solver to only run up to the time 5e-05.
  4. When ParaView finally opened up, I opened the file "VTK/lagrangian/sprayCloud/sprayCloud_24.vtk" in it.
  5. Then applied the Glyph filter, but with these settings:
    • Glyph type: Sphere
    • Scale Mode: Off
    • Mask Points: unchecked
    • Random mode: unchecked
You might also want to check the values that were read from the VTK file, namely by using the "Spreadsheet View" in ParaView: http://www.itk.org/Wiki/ParaView/Use...readsheet_View - it's possible that some values are of type NaN (Not-a-Number). Which would explain why it crashes.
Best regards,
Bruno
Old   September 28, 2014, 23:53
Na
Thanks Bruno,
I got the post-processing to work by doing following procedure (found from the forum):
I do the following tasks after the solver has finished:
"1) rm -r 0
2) paraFoam
3) in ParaView press apply
4) in mesh parts select kinematicCloud - lagrangian
5) in lagrangian fields U and others > apply
6) menu filters > alphabetical > extractBlock
7) select lagrangian (black cross) > apply
8) glyph > glyph type sphere > radius 0.? > theta resolution 24 > scale mode off > apply
9) choose display color"
I will try with the VTK as you described later. Thank you very much , Erkki
wyldckat and JuanRodriguez like this.
Lagrangian particles injection with interFoam and swak4foam Cluap OpenFOAM Running, Solving & CFD 0 June 12, 2018 11:37
Lagrangian material particles bramv101 STAR-CCM+ 5 October 23, 2017 05:27
How to get Path lines for lagrangian particles? vidyadhar OpenFOAM Post-Processing 0 January 31, 2017 05:38
Corellation dimension of lagrangian particles oswald OpenFOAM Post-Processing 0 January 27, 2016 07:30
Add lagrangian particles to OpenFoam solver luchen2408 OpenFOAM 0 June 2, 2015 03:10
