Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Paraview streamline in 2D
Like Tree2Likes
  • 2 Post By openlb12
Old   September 6, 2014, 15:49
Default Paraview streamline in 2D
Vino
Vino is on a distinguished road
I need to create streamlines for my 2D simulation. When I open the *.vtk file using paraview, the streamline option is not enabled. How can I draw the streamlines ?
Vino is offline   Reply With Quote
Old   October 8, 2014, 22:55
leef
openlb12 is on a distinguished road
Originally Posted by Vino View Post
hey, Vino, have you solved this problem? I met the same problem. Hope you can give me some help. Thank you so much!
openlb12 is offline   Reply With Quote
Old   October 11, 2014, 05:16
leef
hay, Vino,
I solved this problem. As I understand, the ParaView doesn't support 2-component fielddata well. Most of its filters only support for 3-component fielddata if it requires vector input. So your problem may be caused by that your velocity data only has 2 components. My suggestion is expanding your velocity data to 3 components with 0 on the z-direction. Hope it will help you.
wyldckat and zhutaihang like this.
[General] paraview streamline length sawyer89 ParaView 12 February 27, 2020 05:43
[General] Streamline Rendering Improvement in Paraview complexFlow ParaView 0 October 20, 2017 14:55
[General] ParaView: Streamline Vectors FPF ParaView 4 September 13, 2011 05:45
[OpenFOAM] points over streamline in paraView cedric_duprat ParaView 0 January 12, 2010 03:04
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
