Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Plot over curved lines
Like Tree12Likes
  • 7 Post By WaterHammer1985
  • 2 Post By TommyM
  • 1 Post By gigili206
  • 2 Post By Mihir
Old   January 29, 2020, 05:22
Post Plot over curved lines
Tommaso M.
TommyM is on a distinguished road
Hi All,
I need to extract the temperature profile along nozzle walls (attached image).
There is the filter "plot over a line" to my knowledge but it plots only over a straight line, while I need to plot over a curved line.
Any suggestions?
Thanks in advance.
Tommy
TommyM is offline   Reply With Quote
Old   February 3, 2020, 14:25
WaterHammer1985 is on a distinguished road
1. Create a .csv file of the XYZ points that defines the curve
2. Import .csv file into Paraview
3. Apply Filter "Table to Points" to the .csv file
4. Create a polyline of the points (got this from another post awhile back but I don't have link to it): Apply Filter "Programmable Filter".
output.Points = inputs[0].Points
numPoints = len(output.Points)
pointIds = vtk.vtkIdList()
pointIds.SetNumberOfIds(numPoints)
for i in range(numPoints):
    pointIds.SetId(i, i)
output.Allocate(1, 1)
output.InsertNextCell(vtk.VTK_POLY_LINE, pointIds)
5. Then use Filter "Slice Along Polyline" using the newly created polyline from step 4.
There may be a more streamlined approach to this workflow but this has worked for me.
WaterHammer1985 is offline   Reply With Quote
Old   February 4, 2020, 13:30
Tommaso M.
Thanks for your help. It works!
I have just founded another way that seems to be more simple. I import in Paraview only the "wall" patch and then I use the filter "Plot over intersections" putting the plane to intersect the patch.
Anyway your method can be applied to a generic polyline and it can be used for example to extract the velocity profile around a turbomachine.
Thanks again,
Tommy
Old   December 23, 2020, 14:45
Lil
Lila
Lil is on a distinguished road
I tried this method but I don't know how to get data over the spline created. Any help please?
Thanks
Lili
Lil is offline   Reply With Quote
Old   September 16, 2021, 15:46
M.H
gigili206 is on a distinguished road
Thanks
Lili
I am writing this for anyone who might see this later.
Once you created your slice over poly line, just use the filter "plot on intersection curves" to plot the data. You can export the data using file>save data.
WaterHammer1985 likes this.
gigili206 is offline   Reply With Quote
Old   September 25, 2021, 16:52
Arijit Saha
ari003 is on a distinguished road
While using programmable Filter I'm experiencing this error
ERROR: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.6.0/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx, line 709
vtkPVCompositeDataPipeline (0x55ee6fdd2a80): Input port 1 of algorithm vtkSliceAlongPolyPlane(0x55ee729fbb90) has 0 connections but is not optional.
Warning: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.6.0/VTK/Common/DataModel/vtkDataObject.cxx, line 521
vtkTable (0x55ee7566e340): Attempted to ShallowCopy from null.
Traceback (most recent call last):
File "<string>", line 22, in <module>
File "<string>", line 2, in RequestData
TypeError: 'NoneType' object has no attribute '__getitem__'
Can you tell me how you did this succesfully? Thanks in advance
ari003 is offline   Reply With Quote
Old   March 12, 2022, 17:30
Default Help !
qutadah
qutadah.r is on a distinguished road
Hey,
I am also trying to plot on curved blades, the problem is there are 6 blades in an impeller and I dont know how to get plots for each of the blades and also to be able to differentiate between the left intersection and right intersection sides of the plane with the wall.
I imported the blades VTK and used plot on intersection. However all I get is only one plot and not sure how to make different plots for each blade and each side of the 3D blade respectively.
Here is a photo of what I was able to do till now.
Thanks!
qutadah.r is offline   Reply With Quote
Old   March 13, 2022, 16:55
I'd suggest using what you have and then applying Clip filters (probably will take multiple) to isolate the area of interest.
Old   March 17, 2022, 20:03
qutadah
I have actually used the vtk file and used extractSurfaces, Connectivity (to closest), Slice and plot Data. It worked
Any idea how I could plot it along arc length of the blade? right now, its just pointId or index.
Thanks!
Old   April 7, 2022, 13:41
Mihir
Mihir is on a distinguished road
1. Create a list of x,y,z points of the polyline in excel sheet.
2. In paraview go to filters -->Poly Line Source
3. You will get options to add your co-ordinates, Increase the number of coordinates till you want for your polyline and then directly copy paste the coordinates, then click on apply.
4. Go to filter --> Slice along polyline, then for database select your geometry and for polyline select PolyLineSource and then apply.
5. Finally select filter --> plot on Intersection Curve, If your geometry is in x-y plane, select z normal for the new Plane and then click on Apply.
JohanDiaz and unilord like this.
Mihir is offline   Reply With Quote
Old   April 7, 2022, 16:36
qutadah
actually i just used append to arc length and it worked.
Old   April 6, 2023, 03:32
Default problem of slice orientation
  #12
little_fish is on a distinguished road
hello,
i m trying to do a slice along polyline on a heicoidale pipe, but i have a problem with the orientation of my plan (see picture).
i would like to have a plan with z normal..
is this possible with this filter ? or i have to change my method ?
File Type: jpg Capture d’écran du 2023-04-04 15-36-34.jpg (88.3 KB, 21 views)
little_fish is offline   Reply With Quote
plot Cp over curved line in bend wall using fluent or cfd post hesham Visualization & Post-Processing 1 September 7, 2022 08:07
generating 2d-planar contour plots from a contour plot on a curved surface alinik CFX 3 May 21, 2016 06:17
plot pressure profile along curved pipe Amar Kad CFX 1 March 20, 2016 18:46
How to plot contour lines in Tecplot 360 using Excel file Iqbal Tecplot 1 May 30, 2012 19:22
plot vectors perpendicular to curved surface azmir Siemens 3 October 19, 2004 01:48
