Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Size *** is not equal to the given value of ***
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 24, 2015, 17:09
Default Size *** is not equal to the given value of ***
Jimmy
MtnRunBeachBum is on a distinguished road
I am trying to view a solution in ParaView (paraFoam). When I try to step through the timesteps, after the first step or two I get the following:
-->FOAM FATAL IO ERROR:
size 500000 is not equal to the given value of 740324
From there the error message indicates the crash occurred while trying to read the p file for the corresponding timestep. I know that 500000 is the size of my overall mesh from blockMesh, but I cannot figure out where 740XXX comes from. More importantly (I think), I cannot figure out where OF is getting that value from; I would say that value was written (somehow, maybe a previous block mesh iteration?) to some file or dictionary, but I cannot figure out where. Perhaps another possibility is the block mesh info isn't playing nice with the snappyHeMesh info, though I don't even know if that's a thing.
I've tried copying over the directory and clearing out any created files, but to no avail.
Any insight?
Cheers,
Jimmy
MtnRunBeachBum is offline   Reply With Quote
Old   April 25, 2015, 07:01
Retired Super Moderator
Bruno Santos
Quick answer: My guess is that you did not run snappyHexMesh with the "-overwrite" option:
snappyHexMesh -overwrite
Old   April 25, 2015, 10:09
Jimmy
That makes sense. I'll give that a shot. I guess I would have thought sHM would overwrite old results/data by default. Is that more of a OF thing or Linux thing?
Old   April 25, 2015, 15:09
Bruno Santos
Quick answer: When in doubt, use the option "-help":
snappyHexMesh -help
which can work with most applications in Linux.
mdhfiz likes this.
Old   May 28, 2021, 22:40
A
David Jean is on a distinguished road
Hi.
I am using OpenFOAM I meet a problem like that. Could you help me to solve this problem? Thank you so much. I hope you are doing well.
David Jean is offline   Reply With Quote
[blockMesh] edges not aligned with or perpendicular to non-empty directions ynos OpenFOAM Meshing & Mesh Conversion 6 March 26, 2020 15:02
[ICEM] Effect of globle mesh size and mesh independency sujay ANSYS Meshing & Geometry 20 September 29, 2019 07:36
Number of cells in mesh:16000 does not equal size of cellLevel:24400 rupesh_w OpenFOAM Pre-Processing 1 February 15, 2016 11:00
Hydrocyclone simulation and catalogue size problem alexandre.david CFX 8 May 15, 2015 08:40
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 10, 2007 23:23
