Home > Forums > Visualization & Post-Processing Software > ParaView
[General] extracting free surface_vertical slosh
Old   December 22, 2015, 00:56
Default extracting free surface_vertical slosh
hydraulist is on a distinguished road
This post i'm reposting from the OF post processing forum, since it is mainly on paraview.
I'm using OF2.3.1 with ParaView 4.1.0 for my project. I'm studying the sloshing problem in rectangular tank with horizontal and vertical excitation applied separately. The excitation is through input displacement generated through gen6DoF application. i could do the horizontal excitation case and extracted the free surface at various x locations of the tank (tank base is in x-z plane) as explained in spillway tutorial, using paraview option.
'https://www.hpc.ntnu.no/display/hpc/OpenFOAM+-+Spillway+Tutorial'
But while doing the same procedure for vertical excitation and trying to extract the free surface, in all variables (alpha.water, U, p...) the data is 'nan' for all possible x locations of tank. But visually i could see the surface oscillation in tank. The possible reason for 'nan' i could find is, the line over which variables are integrated is going out off the flow domain in all time steps, because the line is not moved with tank.
Since my tank is moving vertically up and down with time, in most of the time steps the drawn line goes out of flow domain.
Is there any way to fix the line to tank or any other possible way to overwrite all nan values to zero.
Please help me to overcome this issue.
Thank you,
hydraulist is offline   Reply With Quote
Free surface sensitivity - drag coefficient & mesh sizes SYL Main CFD Forum 1 May 15, 2023 11:53
META Publishing: free and open-access platform for Electromagnetics and Photonics metapublishing Electromagnetics 0 December 29, 2016 12:42
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 19:36
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 06:27
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 15:56
