Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Error message "Data Range too small to render"
Old   January 2, 2017, 03:59
Default Error message "Data Range too small to render"
desip is on a distinguished road
Dear all,
I'm using Paraview 5.2.0 in the 64 bit version. Everything works just fine so far, but now I'm getting a weird error:
I'm having a OF case of a channel, with velocity induced flow in positive x direction. The pressure is set at the outlet. Unfortunately I cannot visualize the pressure field in PV. For the pressure the render view shows just the nan color. If i take a closer look onto the color map editor, the "Mapping Data" field says "Data Range too small to rendering". But the values look good in my opinion. No nan values und the values lie in between 1e-4 and 1e-06. I absolutely have no clue what might be the problem here!
Any ideas?
Best regards
Désirée
desip is offline   Reply With Quote
visualisation
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
[General] Plotting data on a plane in the 3D render view quantumMag ParaView 0 January 31, 2017 09:16
Experimental data for validation of a 2D conv-div nozzle in mach range 0.2-2.0 DDikeshorn Main CFD Forum 0 January 18, 2017 04:56
XYZ (ASCII format) data points into GAMBIT Neil FLUENT 1 August 7, 2007 09:24
data array too small blair CFX 2 July 2, 2003 01:01
