Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] ParaFOAM for multiregion case only load one region?
Like Tree3Likes
  • 3 Post By xerox
Old   October 8, 2018, 05:14
Default ParaFOAM for multiregion case only load one region?
ff
fxzf is on a distinguished road
I am trying to do post-processing for multiregion using either paraview or paraFOAM. The thing is I only interesting for one region, I don't want to load any other regions.
I tried to use paraFOAM -region xxx. But it still load other regions internalMesh by default. Is it possible to only load one region?
Thanks a lot.
fxzf is offline   Reply With Quote
Old   October 22, 2018, 06:50
xerox is on a distinguished road
you can create paraview files with the following syntax for all regions:
paraFoam -touchAll
After this simply open paraview and load the desired regions.
xerox is offline   Reply With Quote
Negative initial temperature error (chtMultiRegionFoam) jebin OpenFOAM Pre-Processing 60 July 17, 2022 05:10
load different case folder ranius OpenFOAM Programming & Development 2 August 1, 2014 03:12
Transient case in solar load model itsme_kit FLUENT 2 February 16, 2014 11:22
[OpenFOAM] ParaFOAM issue with cavity case mschoenberg ParaView 3 November 21, 2008 03:57
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
