January 24, 2006, 05:24 |
Cutting plane
Anja Stretz
I created a cutting plane with the "Filter cut". Now I would like to display only one side (one half) of the geomerty. Can someone please explain me how to do that? Or is there any other possibility to see what happens inside a 3D geometry? Thanks a lot, Anja |
January 28, 2006, 17:27 |
Hi Anja,
Select original data
Masato Otsuki
Hi Anja,
Select original dataset and trun off the check of "data" in display panel. Other method is to use "clip" filter. |
February 17, 2006, 09:14 |
dear all,
Can we get variab
VVqf
dear all,
Can we get variable profile/data (say, pressure/Velocity profile) through a cutting plane with paraView? i couldnt found any export functionality in paraView.. Thanks. |
February 23, 2006, 05:07 |
New versions of Paraview have
Mattijs Janssens
Rep Power: 26 |
New versions of Paraview have the 'Save Data' option (under the right mouse button) which saves the currently selected item to a file.
You'll probably have to use some vtk code to read them in again since they will be xml. |
February 23, 2006, 05:49 |
Mattijs,
Thanks for the answe
VVqf
Mattijs,
Thanks for the answer! I am using the 2.2 version. I just found the 'Save Data' option under menu File, but under right button no such option. you meant the Latest version(2.4.2)? http://www.paraview.org/HTML/Download.html |
February 23, 2006, 05:54 |
You're right, it probably is o
Mattijs Janssens
Rep Power: 26 |
You're right, it probably is only on the file menu
Let us know if/how you manage to read that data (back into OpenFOAM) |
February 23, 2006, 05:58 |
with the 'Save Data' option un
VVqf
with the 'Save Data' option under menu "File", i can only save file as *.pvd.
not knowing what I could do with *.pvd file ... |
February 23, 2006, 07:19 |
ParaView files: This is the de
VVqf
ParaView files: This is the default file format for ParaView. The data set created by this reader may be of any type supported by ParaView (polygonal, uniform rectilinear, nonuniform rectilinear, curvilinear, or unstructured). The file extension is .pvd. This format supports spatially partitioned and multi-block data. ParaView can write data files in this format. There are no modifiable parameters for reading ParaView files unless the file contains multiple time steps.
http://www.paraview.org/Wiki/ParaView:FAQ let me see, install the newest version, and try to read the the .pvd file |
July 4, 2006, 04:43 |
the cutting plane me
the cutting plane menu has the options: plane and sphere. But I need a cutting cylinder surface. How can I cut the domain with a cylinder? Thanks a lot, Nicoleta |
October 31, 2012, 09:20 |
Avdeev Evgeniy
Rep Power: 21 |
Let's make all questions about cutting plane in one thread.
So, my question is: how can I get view after cutting with coarse mesh cells (not plane)? It have to be like this: http://img-fotki.yandex.ru/get/6614/...5d9a2ac2_L.jpg Thank. |
[Commercial meshers] faceSet of a cutting plane for a internal patch definition | RubenGutiii | OpenFOAM Meshing & Mesh Conversion | 1 | April 17, 2019 05:10 |
Measure the surface of the faces of a triangulated cutting plane | Pagoda | OpenFOAM Post-Processing | 3 | August 20, 2018 09:51 |
Curiosity & Question about cutting plane through axisymmetric region | aerospain | OpenFOAM Post-Processing | 0 | October 4, 2012 04:05 |
plane cutting complex geometry in the middle | Lilly | FLUENT | 0 | July 27, 2011 09:01 |
