Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Data extraction xy plot
Old   January 24, 2006, 06:34
Default Data extraction xy plot
atzaru
Does any anybody know how to export data from FoamX or from Paraview on a line for later post process in Excel or whatever. Concretely i need the velocity profile on a line. How can i take out this data?
Thanks
Old   January 24, 2006, 06:47
Default You want to use sample. For
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
For an example of the setup dict go to
applications/utilities/postProcessing/miscellaneous/sample
niklas is offline   Reply With Quote
Old   January 24, 2006, 09:12
Default Octave in combination with oct
Fabian Braennstroem
braennstroem is on a distinguished road
Octave in combination with octaviz is a good option. In simple words, octaviz gets the functions from paraview into octave...
Works nice.
braennstroem is offline   Reply With Quote
Old   January 28, 2006, 17:18
Default Using paraform, try (1) filte
Masato Otsuki
otsuki is on a distinguished road
Using paraform, try
(1) filter menu --> append dataset
(2) filter meny --> prove
then you can setect prove at the point
ot prove along the line.
(3) save data.
if you don't (1) prove option doesn't appear.
You can select several data format but every
format is encoded. Windows version of paraview
can save data in CVS.
otsuki is offline   Reply With Quote
how do i fix installation error of ansys 19.0 on ubuntu 18.04 rid_taki ANSYS 15 June 7, 2021 06:32
[OpenFOAM] Paraview: Plot over line only displays line for untranslated data Illmatic ParaView 1 January 13, 2020 11:42
UDF value to large for defined data type Anna73 Fluent UDF and Scheme Programming 9 September 30, 2018 22:18
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
studying a valve case mina.basta OpenFOAM 33 August 30, 2013 04:46
