Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraView ERROR: In ..... Servers/ServerManager/vtkSMProxyManager.cxx, line 368
Old   September 10, 2010, 02:28
Default paraView ERROR: In ..... Servers/ServerManager/vtkSMProxyManager.cxx, line 368
Martin
RugbyGandalf is on a distinguished road
since today my paraView reports the following ERRORS for every case i open:
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-1.7.0/ParaView-3.8.0/Servers/ServerManager/vtkSMProxyManager.cxx, line 368
vtkSMProxyManager (0x1294550): No proxy that matches: group=sources and proxy=PV3FoamReader were found.
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-1.7.0/ParaView-3.8.0/Servers/ServerManager/vtkSMDeserializer.cxx, line 58
vtkSMCompoundProxyDefinitionLoader (0x1b38aa0): Could not create a proxy of group: sources type: PV3FoamReader
does anyone have an idea about the reason and how to solve it?
i have already re-installed, but this error still occurs
thank you very much
Martin
RugbyGandalf is offline   Reply With Quote
Old   September 10, 2010, 05:52
Retired Super Moderator
Bruno Santos
Greetings Martin,
If OpenFOAM and ParaView weren't open source, I would say that your license had expired
OK, probably ParaView is up to no good once again (i.e., bugs). It might be something that got corrupted in ParaView's config file, which won't reset automatically even after reinstalling. Try following the instructions from this post: paraview 3.8 auto rescale doesn't work #6
Best regards,
Bruno
Old   September 10, 2010, 08:03
Martin
hmmmmm...
thanks for your answer...
the -dr option did not work... and i don't know how to handle the sed option..!?
isn't it possible to delete the config - or whatever file may be damaged - and install paraview once again?
Old   September 10, 2010, 08:43
Bruno Santos
Hi Martin,
The "-dr" option should have the similar effect to removing the file "~/.config/ParaView/ParaView3.8.0.ini".
It's also possible that something got damaged if you updated your Linux system.
Best regards,
Bruno
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
[Gmsh] No cells read from file ".msh" hwsv07 OpenFOAM Meshing & Mesh Conversion 5 August 13, 2018 15:42
[OpenFOAM] could not open file .vtk in paraview ali_atrian ParaView 8 August 27, 2014 10:31
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
