Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview_data_root
Old   May 5, 2010, 12:39
Default Paraview_data_root
heavy_user is on a distinguished road
Hey There,
i would like to post process things with ParaFoam.
Unfortunately I figuered that my "python shell is not available" klicking on tools->pythonshell. I found that i could set "PARAVIEW_ENABLE_PYTHON" to true before compiling, but where?
So I tried to use html for tools->record test.
But when I reuse the script he complains that I did not save the screen shots in "PARAVIEW_DATA_ROOT". But where can I find "PARAVIEW_DATA_ROOT" or define it if it is not available?
Thx & regards!
heavy_user is offline   Reply With Quote
Old   May 6, 2010, 21:26
Retired Super Moderator
Bruno Santos
Greetings heavy_user,
OK, it's as simple as pie... well, sort of. In the folder ThirdParty-1.6 you have a script named makeParaView and a link named makeParaView-python. Now, if you follow the instructions for building Paraview in OpenFOAM's README, but if instead of running:
./makeParaView
You run:
./makeParaView-python
At the end of the building process (and assuming all goes well), you will now have python scripting in Paraview
But don't forget to install python, before re-building Paraview!!
And hopefully, the rebuild process will fix the problem you've had with:
Best regards,
Bruno
Old   May 18, 2010, 09:32
Hi Bruno,
thanks a lot!!
It was that easy !!
(i have looked at some places, but NOT there )
regards!
./makeParaView
You run:
And hopefully, the rebuild process will fix the problem you've had with:Best regards,
Bruno
