Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] do particle tracking in paraview?
Like Tree24Likes
Old   May 27, 2014, 11:05
yes
ENKIME is on a distinguished road
Thanks Paul It works
King Regards
ENKIME is offline   Reply With Quote
Old   March 24, 2015, 05:30
Default Particle tracking in ParaView 4.1.0
  #42
atlan is on a distinguished road
I was trying to use the procedure from 7islands for the particle tracking in ParaView 4.1.0, however some filter as ParticlePathlines or Pathlines are missing. I tried to use filter ParticlePath, however it does not work. Can somebody advise me how to track a particle (defined e.g. by point source) over simulation time in ParaView 4.1.0? I use interFoam solver.
Atlan
atlan is offline   Reply With Quote
Old   May 4, 2015, 10:18
Default There is a tutorial on the wiki now
  #43
Rudolf Hellmuth
rudolf.hellmuth is on a distinguished road
The example showed by 7islands in now on the wiki. Link here.
wyldckat and Luttappy like this.
rudolf.hellmuth is offline   Reply With Quote
Old   October 4, 2015, 03:21
Default foamToVTK- nothing in scalar nor vector of lagrangian cloud
  #44
Alireza Atrian
ali_atrian is on a distinguished road
hi
i am using DPMFoam.
i run 1. foamToVTK and then 2. open the kinematicCloud file and then 3. glyph.
but i see nothing in Scalars and Vector. does any one know whats the problem!?
i have all the properties of my lagrangian particles in all the times folder. and i can see them by parafoam. but i dont know whats the problem with the foamToVTk.
should i do any thing any rather than the steps i mentioned?
ali_atrian is offline   Reply With Quote
Old   October 4, 2015, 03:35
Alireza Atrian
oh, srry
i found what was the problem. it seems i have to choose the files of lagrangian cloud for each separated time not the whole files all together!
but can i have all the time steps in paraview after foamToVTK?
the other question of mine is that how can i plot the curve for the surface of my particles ?
Old   December 8, 2016, 13:14
Default how to use particle tracking and entering in paraview?
  #46
ali
ebtedaei is on a distinguished road
Dear All,
I am a new user in OpenFOAM and paraview and want to enter the particles in my case...But I do not know it and need it very much.
Please tell me those steps of entering and tracking particles in paraview as simple!
Thanks in advance!
Ali
ebtedaei is offline   Reply With Quote
Old   August 30, 2018, 05:02
Federico Cane'
Fred90ar is on a distinguished road
Originally Posted by 7islands View Post
Hi guys,
Or in case if you want to create particle tracking with pathlines that animates over time completely within ParaView from case without lagrangian data, yes you can, but with a bit complex visualization pipeline (see the Pipeline Browser in the screenshot attached below).
The key is to apply Temporal Interpolator that allows you not only to interpolate saved time steps (that are typically too sparse to create a smooth particle tracking animation by themselves) but also to access temporal filters of ParticleTracer and Particle Pathlines. And note that you can create particle seeds from whatever source you like (Plane, Point Source Line, etc) in the Sources menu.
There are lots of options across the filters and sources that affect the formation of the pathlines so you need to do some experiments. Also, in my experience ParticleTracer of ParaView 3.8.0 often crashes ParaView so you might need a git version of ParaView 3.9.
Takuya
Hi 7islands,
I was interested in the procedure that you attached to get particle tracking without performing it in the fluid solver, but just computing in Paraview.
Unfortunately I can not open your attachment.
Could you please send me the steps of the procedure?
Thanks in advance for your help
Fred90ar is offline   Reply With Quote
Old   August 31, 2018, 18:55
Retired Super Moderator
Bruno Santos
@Fred90ar: The answer to your request is already answered a few posts above:
Old   September 4, 2018, 04:22
Federico Cane'
Thanks @wyldckat for your reply!
The problem is that when I apply the ParticleTracer filter Paraview ( I tried both version (5.4.1, 5.5.2 and 4.4.0) stops immediatly without giving any description of the kind of error.
As suggested in the previous steps, I performed a TemporalInterpolator filter but I noticed (trying several times) that gives different results with the same input parameters.
For the ParticleTracer filter, I defined as input the volume mesh where are contained the velocity information and as source I selected the inlet plane of my CFD model.
Did anyone experience the same problem with ParticleTracer?
Old   February 11, 2021, 08:58
Smile Was having same issue, but it worked later on
  #50
Sourav Mandal
sourav90 is on a distinguished road
It''s late but as I was facing similar problem. It might due to some trivial problems, as I was having one. In paraView, in stead of using the "plane" or "line", I was extracting an array of cells with "Extract Cells By Region". Also I tried to uncheck "Skip Zero Time" in the Properties pane of the "<case>.foam file. Both resulted in crashes without any error message. Bottom line, it works if the steps mentioned here are followed exactly: https://openfoamwiki.net/index.php/H...er_in_paraFoam
sourav90 is offline   Reply With Quote
[OpenFOAM] ParaView ErrOr soheil nazmdeh ParaView 1 August 17, 2013 07:40
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
particle tracking in unsteady flow peterchen FLUENT 1 July 22, 2010 22:18
restarting lagrange (particle tracking) simulation dbdias CFX 0 September 22, 2007 19:26
