Cp (Pressure coefficient) using OpenFOAM
Old   July 21, 2012, 22:30
Default Cp (Pressure coefficient) using OpenFOAM
hfs
hfs is on a distinguished road
Hello everyone!
I am doing a wind simulation on a membrane. I am interested in the Cp values on the membrane surface... any ideas how to get it?
Thank you!
hfs is offline   Reply With Quote
Old   August 22, 2012, 09:52
Rider is on a distinguished road
I use this thread to ask my question.
How can I get this type of pressure coefficient (Cp) graph? (cf. picture)
Thanks
Rider is offline   Reply With Quote
Old   August 30, 2012, 08:16
anybody ?
Old   September 11, 2012, 09:47
Tobi's Avatar
Tobias Holzmann
Pressure coefficent ?
Do you mean the lift and drag coefficents?
Tobi
Old   September 12, 2012, 09:30
Not really. I have my lift and drag coefficients (Cl and Cd), but I would like to see the distribution of the pressure around the geometry.
Old   September 26, 2012, 05:29
aerogt3 is on a distinguished road
You can calculate them very easily inside of paraview. Then they can be display in the same way as any other variable.
aerogt3 is offline   Reply With Quote
Old   September 26, 2012, 06:03
Can you explain me how to do that ?
Thanks
Old   September 26, 2012, 08:31
It's very easy. Select the data you want to operate on (the full case, a single surface you have extracted, etc.) Highlight that and click the calculator button, or go
Filters > Alphabetical > Calculator.
You can select point or cell data, and then use it as a normal calculator, using the Scalar/Vector variables available at the bottom. Hit apply and it will calculate.
Old   November 8, 2012, 08:54
Doug68 is on a distinguished road
I am struggling with a similar issue to Rider, trying to work out the center of pressure for a shape.
Search has failed me so far, any advice would be appreciated.
Thanks.
Doug68 is offline   Reply With Quote
Pressure coefficient Giuseppe FLUENT 2 July 26, 2015 03:19
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Problem in Result of the pressure coefficient Ken Choi Main CFD Forum 2 March 15, 1999 04:15
