Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
pressureTools postProcessing function objects in 2.2.0
Like Tree7Likes
Old   August 16, 2014, 12:22
Retired Super Moderator
Bruno Santos
Greetings to all!
@Brock: That wasn't possible in OpenFOAM 2.2, but it is possible to do in OpenFOAM 2.3. The source code file in question is this:
$FOAM_SRC/postProcessing/functionObjects/utilities/pressureTools/pressureTools.C
As of 2.3.0, at the end of each time step, it will execute the calculation of this requested pressure.
Best regards,
Bruno
Old   August 20, 2014, 08:57
BenJ is on a distinguished road
Hi!
Thank you GRAUPS, it works perfectly now!
Now I hop this static pressure field can be used to change from simpleFoam to rhoSimpleFoam
Best regards
Benjamin
BenJ is offline   Reply With Quote
Old   August 28, 2014, 11:02
Brock Lee
GRAUPS is on a distinguished road
@Bruno: Thanks for your comment. You are correct, OpenFOAM 2.3 now executes the calculation after every time-step.
@Ben: Glad I could help!
GRAUPS is offline   Reply With Quote
Old   September 22, 2014, 17:22
Default pressureTools
  #24
James Rodgers
jrwrodgers is on a distinguished road
Dear all,
I'm trying to get "pressureTools" function to work with simpleFoam but I get the error shown below. I've checked and the files were definitely compiled so should be available to call. Can anyone offer an insight?
Thanks,
James
--> FOAM FATAL ERROR:
Unknown function type pressureTools
Valid functions are :
17
cellSource
faceSource
fieldAverage
fieldCoordinateSystemTransform
fieldMinMax
fieldValueDelta
nearWallFields
patchProbes
probes
processorField
readFields
regionSizeDistribution
sets
streamLine
surfaceInterpolateFields
surfaces
wallBoundedStreamLine
My function call looks like this:
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
 pressuretools1   // user-defined name of function object entry
        type            pressureTools;
        libs ("libutilityFunctionObjects.so");
        //region          defaultRegion;
        enabled         yes;
        //timeStart       0;
        //timeEnd         10;
        outputControl timeStep;//outputTime;//
        outputInterval 1; // 5000;
        calcTotal   yes;
        calcCoeff   yes;
jrwrodgers is offline   Reply With Quote
Old   September 23, 2014, 04:41
James Rodgers
So.. I have had some success!
I need to change the library reference to:
functionObjectLibs ("libutilityFunctionObjects.so");
However, I then needed to specify:
pRef
pInf
rhoInf
UInf
And the result was total pressure coefficient (Cp0) being calculated but not static pressure coefficient (Cp)? Will the function only calculate one or the other or can you get it to calculate both?
The modes of operation are:
\table
Mode | calcTotal | calcCoeff
static pressure | no | no
total pressure | yes | no
pressure coefficient | no | yes
total pressure coefficient | yes | yes
\endtable
Any advice gratefully received!
Thanks
Old   April 6, 2015, 13:48
Bruno Santos
Greetings James,
Sorry for the very late reply, but only today did I finally manage to take a look into this.
From what I can see from another post you've done, you've found a solution:
Originally Posted by jrwrodgers View Post
I'm by no means an expert but when through a similar exercise a week ago. I found that to calculate the coefficients both static and total you need to specify the reference static pressure and reference velocity within the pressureTools {}. OF didn't pick up the values from the boundary conditions. I think I ended up specifying also the reference density although this is superfluous for the incompressible simulation I was running.
In addition to your finding, the answer to your previous post:
... is that you would need to add two function object entries instead of just one, e.g.:
pressuretools1
pressuretools2
Only then will your be able to get the two types of results calculations.
Best regards,
Bruno
Old   December 17, 2015, 07:12
SM
canopus is on a distinguished road
Is it possible to write an areaAverage pressure along an axis as asked here using pressure tools?
Thanks
canopus is offline   Reply With Quote
Old   March 28, 2016, 16:15
Bruno Santos
Quick (late) answer: "pressureTools" currently only calculates for the whole pressure field. You could then use one of the resulting fields to be averaged instead of the "p" field.
Old   April 8, 2016, 09:23
ArielJ
arieljeds is on a distinguished road
Hi there,
Is it possible to use pressureTools as a sample instead of functionObject? I added this piece of code to my controlDict:
functions
       pressureTools1
       	 type 	pressureTools;
       	 source		wall;
       	 sourceName	cylinder;
       	 log		yes;
       	 outputInterval	1;
       	 //enabled	yes;
       	 calcTotal	no;
       	 calcCoeff	yes;
       	 pRef		0;
       	 rhoInf		1.0;
       	 pInf		101325;
       	 UInf		(0.4208 0 0);
Which did something really weird on running... data was written to more time steps and the velocity field was not saved except at the written time steps, so I couldn't properly postprocess anything (or view the simulation in paraview or paraFoam).
Two questions:
1) Can I set this up in my sampleDict instead?
2) I really just want to calculate the total pressure at probes on the cylinder to calculate the drag from that.... is this the best way to do it?
arieljeds is offline   Reply With Quote
Old   April 10, 2016, 14:09
Bruno Santos
Quick answers:
Originally Posted by arieljeds View Post
outputInterval    1;
Try changing to this:
outputControl    outputTime;
For more details:
After the function object has done its job, either while the solver was running or by running execFlowFunctionObjects, these pressure fields will have been written to the time folder(s).
Then you can use sample to sample over the data in the written fields.
Another alternative I can think of is the tutorial "incompressible/simpleFoam/motorBike/", which in file "system/forceCoeffs" has an example of a function object for calculating the Cd and Cl, if I remember correctly. This file is included by the file "system/controlDict", which is why it will be executed while the solver is running.
Old   April 11, 2016, 06:30
ArielJ
Hi wyldckat,
Thank you for your very thorough response... I have two follow up questions/issues now:
1) I am trying to run execFlowFunctionObjects, which is giving the error that the keyword transport properties is undefined..However, here is my transportProperties file:
|  \\    /   O peration     | Version:  2.1.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
phases (water air);
water
    transportModel  Newtonian;
    nu              nu [ 0 2 -1 0 0 0 0 ] 0.0631;	// Re = 40
    rho             rho [ 1 -3 0 0 0 0 0 ] 1028;
    CrossPowerLawCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
        nuInf           nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
        m               m [ 0 0 1 0 0 0 0 ] 1;
        n               n [ 0 0 0 0 0 0 0 ] 0;
    BirdCarreauCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] 0.0142515;
        k               k [ 0 0 1 0 0 0 0 ] 99.6;
        n               n [ 0 0 0 0 0 0 0 ] 0.1003;
air
    nu              nu [ 0 2 -1 0 0 0 0 ] 1.568e-05; //1.48e-05;  --> current measurement for kinematic viscosity found at engineeringtoolbox.com
    rho             rho [ 1 -3 0 0 0 0 0 ] 1;
    CrossPowerLawCoeffs
    BirdCarreauCoeffs
sigma           sigma [ 1 0 -2 0 0 0 0 ] 0.07;
In this, because the transportModel is Newtonian, I have assumed that the CrossPowerLaw and BirdCarreau stuff is ignored. Is this correct?
2) I am trying to really understand what the pressure I am getting is because I was having issues implementing the calculating for dragForce, and so I want to calculate it from the pressures instead so I can better understand it. In waveFoam, I am calculating two pressures: p_rgh and p. I am understanding that p_rgh is a reference pressure that is calculated and p would then be p = p_rgh + rho*g*h, which would mean then that the total pressure, and then pressures used in the calculation for pressure coefficient, Cp, would be: p + 0.5*rho*Uinf^2 (where I've been taking Uinf from a probe near the inlet). I'll say now that doing it this way has not been yielding results for the Cp that I'm expecting (as in, the value that I'm calculating for Cp is far too high). Is there something I am misunderstanding about the pressures?
Thanks again for your help,
Ariel
Old   November 30, 2018, 04:46
Arthur
amdk136 is on a distinguished road
Hi Ehsan,
Took me a while to get to here, but here goes:
  1. You told me through an email that if you used swak4Foam, you only needed 1 function instead of 3.
  2. Guess what!? swak4Foam 0.2.4 is already available, at least through SVN and at my GitHub account https://github.com/wyldckat/swak4foam (look for the big ZIP button).
    (Side note: Bernhard was at the OFW8 these past days and I think he hasn't had the time to do the final announcements, but he has already provided these news over Twitter.
    ... edit: never mind, he's on top of things : http://www.cfd-online.com/Forums/ope...tml#post433484 post #29)
  3. With this version of swak4Foam, which builds without problems with OpenFOAM 2.2.0, the following additional code for the function object should work as expected:
    outputControlMode outputTime;
    outputInterval 1;
As for the original issue on the previous post, I'll quote what I've already sent you through emails - The following function objects worked well together:
functions
    writeMissingFields
        type writeRegisteredObject;
        functionObjectLibs ( "libIOFunctionObjects.so" );
        objectNames ("phi");
    totalP    // user-defined name of function object entry
        type            pressureTools;
        enabled         yes;
        //timeStart       0;
        //timeEnd         10;
        calcTotal   yes;
        calcCoeff   no;
        pRef 0;
    Average_left
        type           faceSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled on;
        log             yes;
        valueOutput     false;
        surfaceFormat   vtk;
        source          patch;
        sourceName      left;
        operation       areaAverage;
        fields
            p
            //phi // surface fields not supported for sampledSurface
            T
            rho
            h
            U
      reloadTotalP
          type        readFields;
          enabled         yes;
          //timeStart       0;
          //timeEnd         10;
          fields
              "total(p)"
      totalPressure_left
        $Average_left;
        operation       weightedAverage;
        weightField     rho;
        fields
          total(p)
Notes:
  • The function object "readFields" was needed for reloading back into memory the field "total(p)".
  • As for time folders that only have the field "total(p)": it's because of how the function object was created. It only calculates when it has to write the field to file and it is not registered into memory, which is why we have to use "readFields" for loading it back.
  • For this function object to always calculate the field and save it only occasionally, this would require to edit the original source code for the "pressureTools" function object.
Best regards,
Bruno
Can anyone help with the running of this code through chtMultiRegionFoam? (I am using OpenFOAM 6)
I have copied the above into my controlDict folder and I have tried running the following:
chtMultiRegionFoam -postProcess -func writeMissingFields
chtMultiRegionFoam -postProcess -func totalP
chtMultiRegionFoam -postProcess -func Average_left
chtMultiRegionFoam -postProcess -func reloadTotalP
chtMultiRegionFoam -postProcess -func totalPressure_left
in that order.
-I've also tried it without the inclusion of chtMultiRegionFoam in the above order.
-I've also tried running each part seperately as well, but it still doesn't work - I don't get a postProcessing folder, or any sort of results.
I have changed the patch name to the one I require - cyclicFluidInlet. I am completely at a loss, if anyone could help then I would be very greatful.
I have included my controlDict as well (I had to zip it to upload), any other information can be supplied.
Thanks,
Arthur
amdk136 is offline   Reply With Quote
Old   December 22, 2018, 11:06
Bruno Santos
Quick answer: I see that you later on have gotten an answer to your question here: pressure drop using chtMultiRegionFoam
Essentially there were two issues:
  1. "-region regionName" was a missing argument in the command, where "regionName" is the name of the region you wanted to process.
  2. "-func" is not meant to be used with each individual entry inside the controlDict. You could execute without the "-func name" and it would run all of those function objects that were indicated in the controlDict.
amdk136 likes this.
Old   December 22, 2018, 11:15
Arthur
Yeah, it was a general mix up of about 4 different solutions combined which wasn't the best way to go about it. I ended up taking the function object out of the control dict and just made a script to run post processing with the required functions (- func <function>) within that instead which worked a treat!
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
