Using vorticity utility and meaning of curl (U) |
June 18, 2013, 11:13 |
Ali
Rep Power: 14 |
Dear Foamers,
I am planing to use vorticity as a post processing utility. When I hit the vorticity command in terminal the error comes up: Time = 1500 Reading U Calculating vorticity --> FOAM Warning : --> FOAM FATAL IO ERROR: keyword curl(U) is undefined in dictionary "/home/ali/run/2/system/fvSchemes::gradSchemes" 1. Is there any body explain me what the curl(U) is? 2. Is there any suggestion for the most suitable gradSchemes for curl(U) in fvSchemes? I really appreciate for any help. |
June 19, 2013, 14:58 |
Daniel P. Combest
September 27, 2013, 15:34 |
Przemek
Rep Power: 16 |
hi foamers
I have the same problem as aligoger. Did anybody solve this problem? best |
September 27, 2013, 21:01 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@gaza: Quote:
gradSchemes { default Gauss linear; grad(p) Gauss linear; } Code:
gradSchemes { default Gauss linear; grad(p) Gauss linear; curl(U) leastSquares; } Bruno
Last edited by wyldckat; September 27, 2013 at 21:02. Reason: grad(U) -> curl(U) |
September 28, 2013, 01:42 |
Przemek
Rep Power: 16 |
Hi Bruno
In fvScheme I had set up gradSchemes { default none; grad(p) Gauss linear; grad(U) Gauss linear; } Today when I changed this to gradSchemes { default Gauss linear; // grad(p) Gauss linear; // grad(U) Gauss linear; } it works. I don't know why and this is strange for me. I haven't had to set up curl(U). Very thank you for your ultra fast replay and help. best Przemek |
September 28, 2013, 01:50 |
Przemek
Rep Power: 16 |
It seems that settings: default none
in gradSchemes cannot be set up if I want to calculate vorticity with vorticity utility. best Przemek |
[mesh manipulation] Usage of polyDualMesh utility | vaina74 | OpenFOAM Meshing & Mesh Conversion | 11 | October 16, 2019 05:54 |
stressComponents utility in LES calculations | vkrastev | OpenFOAM | 3 | April 12, 2011 12:57 |
