December 9, 2013, 11:16 |
data extaction of boundary layer thickness
Karthik Goli
Rep Power: 12 |
Hi
I would like to validate my results of flow over a flat plate with blasius solution. I run the case in simplefoam and i could see my results in parafoam. However i would like to compare the boundary layer thickness with blasius solution along the flat plate, but unsuccessful in extracting the data from the results i got. I am trying to extract the data from parafoam is that possible, i also tried using sampledict file but it shows nothing. How can i extract the data from the results i got. Please help me with your suggestions. Thank You Karthik Goli |
December 16, 2013, 16:40 |
Ben Graves
Rep Power: 13 |
Hi Karthik,
A few suggestions: 1. Blasius' solution is for laminar flat plate flow, if you are using simpleFoam, which is a turbulent solver, make sure in the RASProperties file you have laminar selected as the "turbulence model" and turbulence turned off. I recommend using icoFOAM if you are solving a laminar problem. 2. In ParaFOAM you can get the data by using the filters>data analysis>plot over line. Once you have generated the graph then go to file> save data. 3. The sample file is probably empty because you are specifying data points outside your domain. Hope this helps, -Ben |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Boundary Layer roughness/ low reynolds wall treatment | Luigi_ | STAR-CCM+ | 1 | March 14, 2012 08:40 |
Wall coordinates and boundary layer thickness | bentmol | Main CFD Forum | 1 | July 3, 2011 20:44 |
Boundary layer thickness in Xfoil | Nixmich | Main CFD Forum | 5 | January 27, 2011 03:59 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
