how to use foamLog?
Like Tree5Likes
  • 5 Post By Bloerb
Old   January 29, 2014, 16:46
Default how to use foamLog?
Mehdi Famouri
mehdi8619 is on a distinguished road
Hey guys, I'm a rookie and trying to figure out how to use foamLog.
1- Is these two lines all I'm supposed to do? for "cavity" as an example
famouri@ubuntu:~/cavity$ foamJob icoFoam
famouri@ubuntu:~/cavity$ foamLog log
2- Is there any way to have all those data in one file? Like a file with more than two columns.
3- How can I add something not listed there as default?
Thank you in Advance
Mehdi
mehdi8619 is offline   Reply With Quote
Old   February 5, 2016, 04:59
Lennart
elmo555 is on a distinguished road
I'd be interested in this as well.
elmo555 is offline   Reply With Quote
Old   February 5, 2016, 09:56
Bazinga is on a distinguished road
1) Basically, yes.
Here is a bit more information:
http://web.student.chalmers.se/group...ngLucchini.pdf
2) To my knowledge, no. You need to read each file separately.
3) Doesn't foamLog already take basically all information of the log file? What kind of information do you want? I think you would need to work in the code of the utility to change things.
Bazinga is offline   Reply With Quote
Old   March 29, 2016, 05:08
Default deltaT from foamLog
Malthe V. Eisum
Malthe Eisum is on a distinguished road
I have the same question.
Below is an example of a log file (pimpleFoam, slightly modified)
Courant Number mean: 0 max: 0 velocity magnitude: 0
deltaT = 0.00107403
Time = 0.00107403
dU0dt = dU0dt [0 1 -2 0 0 0 0] (3.51258e-06 0 0)
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 2.89979e-10, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG:  Solving for p, Initial residual = 2.91879e-09, Final residual = 2.91879e-09, No Iterations 0
time step continuity errors : sum local = 1.47332e-28, global = 4.77833e-29, cumulative = 4.77833e-29
GAMG:  Solving for p, Initial residual = 3.51043e-09, Final residual = 3.51043e-09, No Iterations 0
time step continuity errors : sum local = 1.77196e-28, global = 7.76479e-29, cumulative = 1.25431e-28
DILUPBiCG:  Solving for Ux, Initial residual = 2.87496e-09, Final residual = 2.87496e-09, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 4.41294e-11, Final residual = 4.41294e-11, No Iterations 0
GAMG:  Solving for p, Initial residual = 3.116e-09, Final residual = 3.116e-09, No Iterations 0
time step continuity errors : sum local = 1.57287e-28, global = 5.77382e-29, cumulative = 1.83169e-28
GAMG:  Solving for p, Initial residual = 3.54987e-09, Final residual = 3.54987e-09, No Iterations 0
time step continuity errors : sum local = 1.79187e-28, global = 6.37111e-29, cumulative = 2.46881e-28
ExecutionTime = 0.05 s  ClockTime = 0 s
Courant Number mean: 1.56175e-29 max: 8.27559e-12 velocity magnitude: 4.59998e-10
deltaT = 0.0012803
Time = 0.00235434
dU0dt = dU0dt [0 1 -2 0 0 0 0] (3.52066e-06 0 0)
DILUPBiCG:  Solving for Ux, Initial residual = 0.999568, Final residual = 3.42989e-10, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 4.96118e-11, Final residual = 4.96118e-11, No Iterations 0
GAMG:  Solving for p, Initial residual = 3.97586e-08, Final residual = 3.97586e-08, No Iterations 0
time step continuity errors : sum local = 2.39233e-27, global = 2.16449e-27, cumulative = 2.41137e-27
GAMG:  Solving for p, Initial residual = 3.47099e-08, Final residual = 3.47099e-08, No Iterations 0
time step continuity errors : sum local = 2.08854e-27, global = 1.8607e-27, cumulative = 4.27207e-27
DILUPBiCG:  Solving for Ux, Initial residual = 1.58338e-09, Final residual = 1.58338e-09, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 9.32757e-11, Final residual = 9.32757e-11, No Iterations 0
GAMG:  Solving for p, Initial residual = 3.28166e-08, Final residual = 3.28166e-08, No Iterations 0
time step continuity errors : sum local = 1.97462e-27, global = 1.74678e-27, cumulative = 6.01885e-27
GAMG:  Solving for p, Initial residual = 2.58746e-08, Final residual = 2.58746e-08, No Iterations 0
time step continuity errors : sum local = 1.55691e-27, global = 1.17718e-27, cumulative = 7.19603e-27
If i run
formLog
i get the following outputs.
  • CourantMax
  • CourantMean
  • Separator
  • Time
  • Ux
  • UxFinalRes
  • UxIters
  • Uy
  • UyFinalRes
  • UyIters
  • contCumulative
  • contGlobal
  • contLocal
  • executionTime
  • p
  • pFinalRes
  • pIters
Is there a way I can get foamLog to output deltaT ? it is listed the same way as Time.
Writing this post I realised I can use the xy file of Time and still get the initial time step. But post any way out of professional curiosity and I know how to modify the solver to log a line of text with a value and can see the combination of this and formLog as a good combination in future use
Malthe Eisum
Malthe Eisum is offline   Reply With Quote
Old   April 7, 2016, 17:46
Bloerb will become famous soon enough
One thing to consider is that a new residuals function object was introduced in 2.4.0 to make this simpler.
You can add this to your controlDict. Should look something like this.
functions
    residuals
        functionObjectLibs ("libutilityFunctionObjects.so");
        type            residuals;
        outputControl   timeStep;
        outputInterval  1;
        fields
            U
            p
It outputs it way easier to handle
More importantly you should learn about typical linux commands like sed awk cat and grep to make your life easier.
Quick example: grep searches for a pattern and outputs the line containing it. This outputs every line with "delta T =" in it. You can add > myFile to output this command to a file.
grep 'deltaT = ' log
The same can be done with sed. foamLog is just a shell around these commands. If you look into the code behind it you can for example see
getSolvedVars()
    fgrep ' Solving for ' $1 | fgrep ',' | sed -e 's/.* Solving for \([^,]*\)[,:].*/\1/' | sort -u
fgrep is equal to grep -f which stops error outputs. $1 is the name of your logfile.
The | is a pipeline command. It gives the result of the first to the second query.... I think the fastest way to learn on how to extract only the value of deltaT or something more fancy is googling how to do it with grep, awk or sed since it is possible with all three of them.
Bloerb is offline   Reply With Quote
Using foamLog liamm OpenFOAM Running, Solving & CFD 17 September 10, 2020 04:00
foamLog problem Rickard.Solsjo OpenFOAM Post-Processing 11 November 19, 2014 20:57
foamLog fferroni OpenFOAM Post-Processing 8 May 21, 2012 17:05
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 10:01
FoamLog for my case liugx212 OpenFOAM Running, Solving & CFD 9 June 18, 2008 13:12
