May 13, 2010, 18:45 |
Friction velocity in Channel flow
Kim Yusik
Rep Power: 16 |
Dear Foamers.
I use a pisoFoam based solver and have turbulent inlet boundary(using LES), I hope the turbulence doesn't decay or develop through channel.(like channelFoam) To normalize the result, I need to know the friction velocity(u_tau or u*). when I use channelFoam, I can output the dpdx in each time, so from there I could calculate the friction velocity. but pisoFoam case, I have no idea. So, I am wondering is there any utility to calculate friction velocity. or equivalent properties. (i.e. u_tau^2 = dp/dx*h = tau_w/rho, where h is half depth of channel) Thank you very much Yusik |
Complex problem: Open Channel Flow | lett | FLUENT | 18 | November 10, 2018 18:30 |
Problem with laminar 2d channel flow | Quarkz | Main CFD Forum | 6 | October 7, 2015 12:24 |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 05:35 |
LES In Turbulent in channel flow | pankaj saha | Main CFD Forum | 8 | April 15, 2009 11:34 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
