gradient and laplacian in OF - how to explicitly get them |
April 7, 2014, 08:34 |
Tom
Rep Power: 14 |
Hi there,
I want to get explicitly the gradient and the laplacian of a variable that I want to select. For example, given a FoamFile of p or U taken like output at a given time from a certain simulation, I would like to have the terms grad(p) or grad(U) and equivalently laplacian(U)... In formulas: grad(p)=(dp/dx,dp/dy) grad(U)=[dU/dx, dU/dy;dV/dx, dV/dy] laplacian(U)=[d^2U/dx^2+d^2U/dy^2, d^2V/dx^2+d^2V/dy^2] How is it possible to have this in OF? Thank you for those who will spend 5 minutes of their time to read this post. Cheers |
April 7, 2014, 09:02 |
Bernhard
Rep Power: 21 |
One solution is to use foamCalcEx: http://openfoamwiki.net/index.php/Contrib_foamCalcEx
Third order derivative: Gradient of laplacian | hrushi.397 | OpenFOAM Running, Solving & CFD | 1 | April 17, 2024 12:59 |
Why Laplacian is used instead of a combination of divergence and gradient operators? | HakikiCanakkaleli | OpenFOAM Programming & Development | 3 | September 26, 2019 07:40 |
gradient or laplacian of an unstructured field | sawyer86 | OpenFOAM Post-Processing | 0 | March 13, 2014 11:40 |
Laplacian containing an implicit and an explicit variable | voingiappone | OpenFOAM Programming & Development | 0 | July 1, 2013 02:40 |
Wall correction for the temperature gradient | Hagen | OpenFOAM | 0 | March 7, 2011 20:04 |
