Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Pressure - correction or not?
Old   September 4, 2014, 07:12
Default Pressure - correction or not?
Dominik Allgaier
Doflo is on a distinguished road
Hello Forum,
I´m new here in CFD Online and also quite new in CFD.
My name is Dominik and we (a collegue of mine as well) are trying to simulate a probe in OpenFoam.
The programme is working and we already have got some results, which qualitative represent our measurement results. But only qualitative and not quantitative.
The thing is, we´re not sure if the pressure scale is actually the rigt one or ih we have to correct it by a factor, the density of the fluid (in this case: air) namely.
I´ve read that you have to correct the pressure by the density afterwards, because OpenFoam computes with density=1 by default.
Otherwise in the transportProperties dict, we typed in the dynamic viscosity which is already a function by the air density. That´s why I´m not sure, if we have to correct the pressure value by the density or not.
Mentioned below, you can see the p-dict.
Here some datas:
programme: BlueFCD 2.3
case: probe calibration, 3 dimensional
Mesher: snappyHex (probe) and BlockMesh
Turbulence Model: komega-SST
Solver: SimpleFoam
Thank you very much for your statements.
Best regards, Dominik
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
#include "include/initialConditions"
dimensions [0 2 -2 0 0 0 0];
internalField uniform 1000;
boundaryField
//- Set patchGroups for constraint patches
// #include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes"
sonde_CreatedbyGmsh
type zeroGradient; //
inlet
outlet
type fixedValue;
value uniform 0;
Bohrung_vorn_CreatedbyGmsh
type zeroGradient;
Bohrung_unten_CreatedbyGmsh
type zeroGradient;
Bohrung_links_CreatedbyGmsh
type zeroGradient;
Bohrung_rechts_CreatedbyGmsh
type zeroGradient;
Bohrung_hinten_CreatedbyGmsh
type zeroGradient;
Doflo is offline   Reply With Quote
Fluidized Bed: Error: Divergence detected in AMG solver: pressure correction Error Ob Mole89 FLUENT 5 April 12, 2014 09:32
Convergence pressure correction equation michujo Main CFD Forum 1 September 25, 2012 03:17
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 01:04
changing the coefficients of pressure correction Noel Phoenics 1 April 7, 2009 08:54
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
