How to extract data from a specific layer of the grids? |
September 17, 2014, 23:37 |
Jack
Rep Power: 14 |
Hi Foamers,
I have a really simple question. I ran a channel flow simulation with 128*100*128 grids in streamwise (x), vertical (y), and spanwise (z) direction. After the simulation, I would like to extract the temperature fields at a specific channel height, e.g., y=50. How can I do that? I know that "sample" utility can do a simple work, but interpolation is always needed. How can I just give a y index and extract the data from specific vertical layer of the grids? (I used non-uniform grids in vertical direction, so I dont want interpolation, I just want raw data from a specific grid layer). Many thanks! Regards, Ripperjack |
October 29, 2014, 08:57 |
Joachim Herb
Rep Power: 21 |
Did you find a solution for your problem? Perhaps these links help:
https://github.com/OpenFOAM/OpenFOAM...m/cuttingPlane http://www.tfd.chalmers.se/~hani/kur...ionObjects.pdf |
[snappyHexMesh] SnappyHexMesh - no layer added | bejbro | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2020 20:05 |
Turbulent Boundary Layer on a Flat Plate | Hoshang Garda | FLUENT | 1 | November 27, 2013 10:24 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Extract data we want from Techplot to a data file | vetnav | Main CFD Forum | 0 | July 28, 2010 20:17 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
