Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
extracting velocity field from 0/U file into matrix format
Like Tree1Likes
  • 1 Post By ssss
Old   November 3, 2014, 11:17
Question extracting velocity field from 0/U file into matrix format
Gowain
eaglemckenna is on a distinguished road
Hi
Does anyone know a methodology or is there a command or scrip in OF to extract the velocity components from the final time step U file into column matrix format? It is not feasible to do this manually due to the number of rows as well as the parenthesis. I intend to perform numerical analysis on the data.
thanks
g
eaglemckenna is offline   Reply With Quote
Old   November 3, 2014, 14:01
anonymous
ssss is on a distinguished road
Maybe this helps but it's not a decent way of doing it:
1) Go to paraView, last time step
2) Go to file save data
3) Save it in csv
4) Open the csv you will see some columns with {U:0} {U:1} {U:2} this are the velocity components.
Hope it helps.
eaglemckenna likes this.
ssss is offline   Reply With Quote
Old   November 4, 2014, 06:43
Smile
Gowain
Thanks so much
Apologies for such an obvious question.
Old   November 5, 2014, 11:29
Arrow
Gowain
Greeting fellow CFD users.
I have created an algorithm to determine POD velocity basis vector for x and y components at each node point for a 2d mesh for 9 observations with Matlab.
I have a column vector x denoting the x co-ordinates at each node and a column vector y for the y co-ordinates.
plot(x,y) gives me the 2d domain.
I have a column vector r denoting the resulting velocity of x and y at each node.
Now all I need to do is map the resultant velocity vector at each node onto the back onto the 2d grid.
What is the command to do this?
I have tried meshgrid, and ndgrid but have no success as of yet.
kind regards
gowain
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
