extracting velocity field from 0/U file into matrix format |
November 3, 2014, 11:17 |
Gowain
Rep Power: 11 |
Hi
Does anyone know a methodology or is there a command or scrip in OF to extract the velocity components from the final time step U file into column matrix format? It is not feasible to do this manually due to the number of rows as well as the parenthesis. I intend to perform numerical analysis on the data. thanks g |
November 3, 2014, 14:01 |
anonymous
Rep Power: 12 |
Maybe this helps but it's not a decent way of doing it:
1) Go to paraView, last time step 2) Go to file save data 3) Save it in csv 4) Open the csv you will see some columns with {U:0} {U:1} {U:2} this are the velocity components. Hope it helps. |
November 4, 2014, 06:43 |
Gowain
Rep Power: 11 |
Thanks so much
Apologies for such an obvious question. |
November 5, 2014, 11:29 |
Gowain
Rep Power: 11 |
Greeting fellow CFD users.
I have created an algorithm to determine POD velocity basis vector for x and y components at each node point for a 2d mesh for 9 observations with Matlab. I have a column vector x denoting the x co-ordinates at each node and a column vector y for the y co-ordinates. plot(x,y) gives me the 2d domain. I have a column vector r denoting the resulting velocity of x and y at each node. Now all I need to do is map the resultant velocity vector at each node onto the back onto the 2d grid. What is the command to do this? I have tried meshgrid, and ndgrid but have no success as of yet. kind regards gowain |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
