Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Display temperature dependent material properties
Old   November 20, 2014, 05:47
Default Display temperature dependent material properties
Paritosh Vasava
vasava will become famous soon enough
I am using chtMultiRegionSimpleFoam to simulate a fluid flow passing by heated walls. The material properties (density, viscosity, Cp etc)are temperature dependent.
rhoCoeffs<8>     ( x x x ......);
CpCoeffs<8>     ( x x x ......);
Is there any way to plot the contours of the material properties? Is is possible with paraview or do I have to modifying the solver somehow?
vasava is offline   Reply With Quote
Old   November 25, 2014, 05:48
Default writeAdditionalFields
Paritosh Vasava
In swak4foam there is a utility named writeAdditionalFields. It writes fields other than the default ones but not the material properties.
chtmultiregionsimplefoam
Time dependent material properties hatef CFX 7 June 8, 2016 10:23
Radiation interface hinca CFX 15 January 26, 2014 17:11
Temperature dependent propertys and finalIteration in chtMultiRegionFoam waiter120 OpenFOAM 0 February 20, 2013 05:22
Temperature-dependent material properties in chtMultiRegionFoam-Solver sebonator OpenFOAM 0 November 15, 2010 08:15
one temperature as liquidus & solidus temperature for pure material sooroo3 FLUENT 0 November 12, 2010 06:21
