April 1, 2015, 06:09 |
Probing field averages
Luuk Buijs
Rep Power: 11 |
Dear Foamers,
I would like to monitor my fieldAverages during runtime using the probes functionality. I have my probes and averages up and running, but the probes won't sample data from the time-averaged fields. There is an instance of both the UMean and TMean field in my 0-directory. Is there any way to get this to work? My controlDict code is as follows: Code:
functions { probes { type probes; functionObjectLibs ("libsampling.so"); enabled true; outputControl timeStep; outputInterval 1; fields ( U T UMean TMean ); probeLocations ( ( 0.025 0.025 0.025 ) ( 0.002 0.025 0.025 ) ( 0.025 0.002 0.025 ) ( 0.025 0.025 0.002 ) ); } fieldAverage1 { type fieldAverage; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl outputTime; resetOnOutput false; resetOnRestart true; fields ( U { mean on; prime2Mean on; base time; } T { mean on; prime2Mean on; base time; } ); } } Many thanks in advance! Luuk |
funkySetBoundaryFields - Manipulation of existing field | jhertel | OpenFOAM Pre-Processing | 16 | May 18, 2020 06:32 |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 18:44 |
New BoundaryCondition: how to modify a single component of a field? | look86 | OpenFOAM Programming & Development | 4 | August 28, 2012 16:48 |
Demagnetization field | jan0385 | ANSYS | 0 | April 12, 2012 09:09 |
chtMultiRegionFoam - exchange data between flow field and temperature | phsieh2005 | OpenFOAM Running, Solving & CFD | 0 | February 7, 2012 09:16 |
