Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Probing field averages
Old   April 1, 2015, 06:09
Default Probing field averages
Luuk Buijs
lcbuijs is on a distinguished road
Dear Foamers,
I would like to monitor my fieldAverages during runtime using the probes functionality. I have my probes and averages up and running, but the probes won't sample data from the time-averaged fields. There is an instance of both the UMean and TMean field in my 0-directory. Is there any way to get this to work? My controlDict code is as follows:
functions
        probes
                type    probes;
                functionObjectLibs ("libsampling.so");
                enabled true;
                outputControl timeStep;
                outputInterval 1;
                fields
                        U
                        T
                        UMean
                        TMean
                probeLocations
                        ( 0.025 0.025 0.025 )
                        ( 0.002 0.025 0.025 )
                        ( 0.025 0.002 0.025 )
                        ( 0.025 0.025 0.002 )
        fieldAverage1
                type    fieldAverage;
                functionObjectLibs ("libfieldFunctionObjects.so");
                enabled true;
                outputControl outputTime;
                resetOnOutput false;
                resetOnRestart true;
                fields
                        U
                                mean    on;
                                prime2Mean on;
                                base    time;
                        T
                                mean    on;
                                prime2Mean on;
                                base    time;
Also, I would like to monitor local Nusselt numbers during runtime using the same functionality. Any suggestions on how to approach this?
Many thanks in advance!
Luuk
lcbuijs is offline   Reply With Quote
funkySetBoundaryFields - Manipulation of existing field jhertel OpenFOAM Pre-Processing 16 May 18, 2020 06:32
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 18:44
New BoundaryCondition: how to modify a single component of a field? look86 OpenFOAM Programming & Development 4 August 28, 2012 16:48
Demagnetization field jan0385 ANSYS 0 April 12, 2012 09:09
chtMultiRegionFoam - exchange data between flow field and temperature phsieh2005 OpenFOAM Running, Solving & CFD 0 February 7, 2012 09:16
