[OpenFOAM] Some problems with paraview2.3.1 for a two-region (Multi-region) postprocessing |
April 14, 2015, 05:32 |
#1 | |
Mehdi Asghari
Rep Power: 16 |
Hi all
I solved a solid heat conduction two-region problem by Openfoam2.3.1. The results seem to be logical and corrrect as those are observed at log.heatconductionFoam file (an output text file). However , whenever I want to observe the total region results in Paraview 2.3.1, I am facing with the following error: Quote:
Of course,if the results are shown separately ,there isn't any problem (for example at heatconduction{solid1}.OpenFOAM & heatconduction{solid2}.OpenFOAM files) and the results are correct. However if the results are shown together in a paraview file containing of two solid regions, I encounter above error message. Can anybody help me how to view the results of total domain in a file without any error? Last edited by Asghari_M; April 14, 2015 at 09:20. |
April 14, 2015, 09:50 |
Mehdi Asghari
Rep Power: 16 |
Actually only I observe temperature fields for Time=0 for total domain and in the Volume Fields table in Paraview.
unfortunately, the temperature field data lost for next times for total domain in a file. Thanks in advance for any help. |
multi-region, paraview 2.3.1, postprocessing |
[Other] mesh interface for multi region | Mohammad Jam | OpenFOAM Meshing & Mesh Conversion | 3 | December 5, 2016 07:23 |
[snappyHexMesh] Convert stl files and multi region | abrunet | OpenFOAM Meshing & Mesh Conversion | 1 | July 1, 2014 10:15 |
Problems about multi swirl tubes simulation using | Jason | FLUENT | 4 | May 9, 2008 00:33 |
Problems in Turbo Postprocessing | Tobias | FLUENT | 6 | October 19, 2005 06:17 |
Win NT, pre and postprocessing with large problems | Dirk | FLUENT | 1 | February 7, 2001 14:50 |
