Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
areaAverage of arbitary plane
Old   June 23, 2015, 04:15
Default areaAverage of arbitary plane
Chris
LilumDaru is on a distinguished road
My problem is that there were allready some simulations running in the past and I'm supposed to collect some data out of it. For this I need to get the areaAverage velocity, areaAverage pressure and areaIntegrated shearstresses inside a fluid on some planes (the positions are not known, the position of the plane should be variable). I allready managed to collect all the field-data using sampleSurfaces. You know, that's a huge amount of numbers... so are there any comfortable ways (allready build tools) to get the areaAverages?
If possible, I would like to integrate everything into a script which does all the analysis for me. (I got some basic programming knowledge in python, matlab and java, but unfortunally not yet in c++)
It would be great if someone could tell me how to execute this runtime processing function in a postprocess (this function is taken from controllDict):
pAverageCuttingPlane1
        type			faceSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        outputControl   timeStep;
        // Output to log&file (true) or to file only
        log             true;
        // Output field values as well
        valueOutput     false;  //true;
        // Type of source: patch/faceZone/sampledSurface
        source          sampledSurface;
        sampledSurfaceDict
                type				cuttingPlane;
                planeType			pointAndNormal;
                pointAndNormalDict
                        basePoint       (0.065 0 0.0015);
                        normalVector    (0 0 1);
                source cells; // sample cells or boundaryFaces
                interpolate true;
        // Operation: areaAverage/sum/weightedAverage ...
        operation       areaAverage;
        fields
            p
	    U
Thanks and regards,
Chris
LilumDaru is offline   Reply With Quote
Using a Plane id in Fluent UDF cdf_user Fluent UDF and Scheme Programming 13 October 17, 2023 00:06
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Plane stress and plane strain cases for stress analysis Sargam05 OpenFOAM 0 May 3, 2013 18:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
