Cartesian to cylindrical velocity field conversion |
January 13, 2009, 09:13 |
Hi all,
I'm looking for a w
Francois Beaubert
Rep Power: 17 |
Hi all,
I'm looking for a way to convert my cartesian velocity field U in a cylindrical velocity field where X is the axial direction. Cartesian UX UY UZ to Cylindrical URadial Utangential Uaxial I know that OpenFOAM has got some coordinate system classes and that for the cylindrical one - the class is called cylindricalCS, but don't know how to use this class in OF 1.5 to convert the velocity field for the whole domain. I did not found an application like Ucomponents to do this kind of postprocessing. Has someone some info on this ? Have a nice day Regards Francois |
January 13, 2009, 10:18 |
Hi Francois,
You'll probabl
Mark Olesen
Rep Power: 40 |
Hi Francois,
You'll probably need to do some coding yourself. I didn't find the application Ucomponents at all, so at least there you are ahead of me! All the classes derived from coordinateSystem also inherit the methods 'globalVector()' and 'localVector()' that you can use to generate a tmp vector field. This is probably what you want. A few things to watch for though: 1) the cylindricalCS class uses r/theta/z, you'll need to watch for this if you want the axis to correspond to the global X direction. 2) cylindricalCS uses degrees for theta. If you want radians you'll either need a new class or need to adjust the class accordingly. |
January 13, 2009, 10:37 |
Hi Mark,
Thanks for your an
Francois Beaubert
Rep Power: 17 |
Hi Mark,
Thanks for your answer. Damned ! I hope such an application was lost somewhere in the path of OpenFOAM. By the way Ucomponents is no more available in OF 1.5 don't know exactly why ... you have to copy the source from OF 1.4 at /OpenFOAM-1.4.1/applications/utilities/postProcessing/velocityField/Ucomponents/ It's quite surprising that nobody has already such an utility. You can find some more info on this post below but it looks like you can't do that for the whole domain but only for some patches. http://www.cfd-online.com/OpenFOAM_D...es/1/2652.html Did someone try to implement this for the velocity field conversion for the whole domain ? |
January 13, 2009, 10:49 |
Mark Olesen
Rep Power: 40 |
Oh, the same functionality is still there - see src/postProcessing/foamCalcFunctions/field/components + applications/utilities/postProcessing/foamCalc - just not as Ucomponents. Unfortunately, it seems that the only way to list the utilities available is provoke a FatalError by supplying "foamCalc -help". Presumable this mechanism should make it easier for you to extend with your utility. |
January 13, 2009, 10:53 |
whaouu don't know this utility
Francois Beaubert
Rep Power: 17 |
whaouu don't know this utility was there, thanks you very much !
will look at it to see if it can be extended to export the radial, tangential en axial components Thanks again Mark |
January 16, 2009, 08:16 |
Hi Francois,
I used the met
Ville Tossavainen
Rep Power: 17 |
Hi Francois,
I used the method explained in this thread by Osamu Nakamura: http://www.cfd-online.com/OpenFOAM_D...es/1/2652.html The radial component can be computed in the same way. I can send you the code if you want. |
January 16, 2009, 12:27 |
Thanks for the tip !
Well ind
Francois Beaubert
Rep Power: 17 |
Well indeed I may be interested by your very kind proposition You can find my email when you clik on my name in the header of this post Thank you very much for your help Have a nice day Regards Francois |
January 16, 2009, 12:30 |
Well ind
Francois Beaubert
Rep Power: 17 |
January 19, 2009, 06:48 |
Hi Francois,
I think you ca
#9 |
florian
Location: Mannheim - Vincennes - Valenciennes, Deutchland - France
Rep Power: 17 |
Hi Francois,
I think you can use the paraview calculator (that you can find in filters/Common) which is able to make operations between field, U components and coordinate. When "attribute mode" is on "point data", you have acces to vectors: (coord, U) and scalars: coordx, U_0 coordy, U_1 coordz, U_2 and many operators (cos, sin ...) Florian |
February 12, 2010, 11:17 |
Coordinate System Components (v, w, x) ?
#10 |
Mdz
Rep Power: 16 |
Hi, I have been using the version of ansys 12.1, and the coordinate system appears with these component (v, w, x) , I have not found the form to change it a (x, y, z), since I can do it?
September 29, 2017, 05:37 |
#11 |
Tom
Rep Power: 9 |
Has anyone managed to solve this problem?
I'm using openfoam 5 and I'm looking to calculate the tangential velocity in order to be able to compute the swirl number. I have everything in cartesian, I'm not sure how to get the tangential velocity |
November 30, 2017, 05:52 |
#12 |
Chris Schäfer
Rep Power: 9 |
Hi, I'am also interested to derive radial velocity. Supprisingly there exists no macro or plugin in paraview to do this job, or do anyone know about this automatically?
BR Chris |
FLUENT bug in cartesian-cylind velocity conversion | Knut | FLUENT | 0 | September 3, 2008 10:52 |
cartesian vs cylindrical solver | giles | Main CFD Forum | 0 | August 26, 2008 19:00 |
change coordinate system cartesian to cylindrical | tht | FLUENT | 0 | September 6, 2007 05:46 |
cartesian to cylindrical coordinate UDF | Manoj | FLUENT | 0 | December 15, 2005 09:43 |
Transformation from cartesian to cylindrical | P.Fonteijn | Main CFD Forum | 0 | October 18, 2001 16:19 |
