August 9, 2013, 12:00 |
reconstructPar does not work in interDyMFoam
Anastasios
Rep Power: 17 |
Dear All,
I am trying to execute "reconstructPar" utillity in a 3d case that I had simulated in ItterDyMFoam decomposed in 16 parts (cores) and I get the following message: z620@Z620:~/OpenFOAM/z620-2.2.1/run/MySimulations/3DBubbleRiseAndDetachment$ reconstructPar /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.1-57f3c3617a2d Exec : reconstructPar Date : Aug 09 2013 Time : 17:56:01 Host : "Z620" PID : 3480 Case : /home/z620/OpenFOAM/z620-2.2.1/run/MySimulations/3DBubbleRiseAndDetachment nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reconstructing fields for mesh region0 Time = 0.001 --> FOAM FATAL IO ERROR: cannot find file file: /home/z620/OpenFOAM/z620-2.2.1/run/MySimulations/3DBubbleRiseAndDetachment/processor0/0.001/polyMesh/pointProcAddressing at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting z620@Z620:~/OpenFOAM/z620-2.2.1/run/MySimulations/3DBubbleRiseAndDetachment$ Can somebody please advise me what to do? Thank you very much in advance ageorg |
August 28, 2013, 10:47 |
Andrea Ferrari
Rep Power: 16 |
Did you solve the problem? andrea |
November 7, 2013, 07:47 |
Kostis
Rep Power: 13 |
try recontstructParMesh
November 8, 2013, 01:29 |
#4 | |
Rep Power: 14 |
exactly: you must use reconstructParMesh before you can use reconstructPar look here: http://www.cfd-online.com/Forums/ope...tpar-15-a.html Sega posted a script for it: Quote:
Last edited by wyldckat; November 9, 2013 at 11:48. Reason: Added [CODE][/CODE] and fixed the quote |
April 15, 2016, 13:25 |
#5 | |
Olabanji
Rep Power: 13 |
I am sure you must have found some solution some way, since this was posted a long time ago. I decided to just post mine just for anybody who runs into the same problem like me. I use OpenFOAM-2.3.x. When you run a problem using AMR in parallel. To reconstruct, first open the system/controlDict file and change the entry for write format from "ascii" to "binary". Then do the following 1) run 'reconstructParMesh' 2) run 'reconstructPar' This works with no problem in 2.3 version, not sure of the rest. Cheers. Quote:
Last edited by banji; April 16, 2016 at 01:48. Reason: Need to add more information for clarity |
Problems with reconstructPar after run interDyMFoam | FG_HSRM | OpenFOAM | 3 | December 13, 2011 11:16 |
InterDyMFoam with GGI | sebastianweiper | OpenFOAM Running, Solving & CFD | 2 | September 18, 2009 03:43 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
