Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to calculate the particles number by paraview?
Like Tree2Likes
  • 1 Post By chpjz0391
  • 1 Post By jairoandres
Old   May 10, 2016, 05:25
Default How to calculate the particles number by paraview?
Ping Chang
chpjz0391 is on a distinguished road
Hi all,
Recently, I used simplereactingparcleFoam to simulate the particle problem. The simulation run well, however, I have a small question.
How can I calculate the particles number in a specified area of the mesh after simulation? In my simulation, I have two different sized particles, can I calculate the number for each size particles? Am I able to use the preview to achieve these goals?
Thanks.
chpjz0391 is offline   Reply With Quote
Old   May 17, 2016, 04:22
Brian Willis
Dipsomaniac is on a distinguished road
Hi Ping
In paraview, if you select a region of interest, then use use the histogram function and define the bins manually for your particle sizes of interest, you should be able to count them, and extract the data.
Regards,
brian
Dipsomaniac is offline   Reply With Quote
Old   May 17, 2016, 23:21
Ping Chang
Originally Posted by Dipsomaniac View Post
Hi Ping
Regards,
brian
Hi, Brian
I have already found that function. Anyway, thank you very much.
Kind Regards,
PING
Dipsomaniac likes this.
Old   January 5, 2017, 11:42
Alberta
Ela89 is on a distinguished road
Hi Brian,
I tried the method you said for counting particles. However, I'm only able to see the number of particles in my region of interest in a certain time step. Is there a way to count the total number of particles in a region throughout my whole simulation? (basically, I'm trying to find out the total number of particles that impact a particular surface).
Regards,
Ela
Ela89 is offline   Reply With Quote
Old   April 7, 2017, 20:19
Karelke Yu
cfdopenfoam is on a distinguished road
Originally Posted by Ela89 View Post
Hi Brian,
Regards,
Ela
Hi Alberta,
Did you find solutions to your problem? I am facing exactly the same situation and I am in desperate need of your hints.
Thank you in advance.
Best,
Karekle
cfdopenfoam is offline   Reply With Quote
Old   April 7, 2017, 20:22
Karelke Yu
Originally Posted by chpjz0391 View Post
Hi, Brian
Kind Regards,
PING
Hi Ping,
I would like to know which function you used. Could you share your method in a more specific way here so that it can help others?
Thanks.
Best,
Karelke
Old   April 10, 2017, 11:32
Alberta
Hi Karekle,
For counting the total number of particles that impact a particular surface, in "kinematicCloudProperties" I changed "localInteractionCoeffs" from rebound to stick for that particular surface. Then in the log file, I could see the number and mass of the particles that impact (i.e. stick to) that particular surface at different time steps. You should check to see if changing from rebound to stick doesn't impact your simulation results. In my case it didn't change the results I was interested in.
Ela
Old   June 7, 2020, 16:37
Jairo A. Gutiérrez S
jairoandres is on a distinguished road
Sticking the particles might change the overall statistics. Better use patchPostProcessing in cloudFunctions
patchPostProcessing
type patchPostProcessing;
functionObjectLibs ("libcloudFunctionObjects.so");
// Optional new entry
fields (age d nParticle);
maxStoredParcels 2000;
patches
wallsNoSlip
CFD-HSNR likes this.
jairoandres is offline   Reply With Quote
Old   June 15, 2022, 01:43
RAJ GAURAV
RAJ_GAURAV is on a distinguished road
Hi all,
Thanks.
Dear Sir, how did you define the bins manually? I am using the same solver in OF.
RAJ_GAURAV is offline   Reply With Quote
how to determine the number of particles injected. welch FLUENT 2 January 18, 2024 04:08
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 09:15
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
