Time step continuity error unit
Old   November 8, 2016, 03:53
Default Time step continuity error unit
Thomas A
tdog is on a distinguished road
Hello
I am trying to figure out the unit of the global time step continuity error. Is it in percent, in decimal percent, or something else entirely?
I hope someone can help :-)
tdog is offline   Reply With Quote
Old   November 14, 2016, 08:18
Thomas A
No one knows?
Old   December 1, 2016, 08:01
Thomas A
Anybody knows?
Old   December 2, 2016, 14:55
Declan
decah is on a distinguished road
Hi Thomas
It's a scalar field representing the sum of all the deviations in the continuity equation (grad.u=0) over all cells. Therefore it is representing flux, not percentages!
Take a look a the continuityErrs.H file in
src/finiteVolume/cfdTools/incompressible/continuityErrs.H
and also this post:
http://www.cfd-online.com/Forums/ope...tml#post201896
decah is offline   Reply With Quote
Old   December 5, 2016, 08:33
Thomas A
Originally Posted by decah View Post
Hi Thomas
and also this post:
Hi, thanks for replying :-)
Ok, so flux, but in what unit? I saw that in the post linked it was for incompressible flow, I'm running rhoSimplecFoam, which is for compressible flows, so the the continuity error file looks like this instead:
dimensionedScalar totalMass = fvc::domainIntegrate(rho);
scalar sumLocalContErr =
(fvc::domainIntegrate(mag(rho - thermo.rho()))/totalMass).value();
scalar globalContErr =
(fvc::domainIntegrate(rho - thermo.rho())/totalMass).value();
cumulativeContErr += globalContErr;
Info<< "time step continuity errors : sum local = " << sumLocalContErr
<< ", global = " << globalContErr
<< ", cumulative = " << cumulativeContErr
<< endl;
If using SI units, the difference between rho and thermo.rho must be in kg/m^3, right? And the total mass is a volume integral over rho, so that must be in kg? I am unsure what value value() takes, but according to the thread it's usually 1, but in what unit?
So that means the unit of globalContErr is 1/m^3 is that correct? How do I then normalise this so I can get it in percentage?
Old   December 5, 2016, 21:20
Declan
I don't work with compressible flows myself, but after running an incompressible simulation I can go to any one of the time directories in the case folder and look at the phi file. Near the top I find: dimensions [0 3 -1 0 0 0 0]; which tells me the units of phi (and therefore units of the time step continuity error in my case) is m3/s (i.e. volume flux).
So you can double check your rho files for the units but it looks to me like your units are rho/mass = (kg/m3)/(kg) = m-3.
Old   December 6, 2016, 10:12
Thomas A
Hey decah, thanks for replying.
Ok, from that it seems like my flux is mass flow with units kg/s. Do I need to compute the mass flux at the inlets in order to normalise the continuity errors?
Old   December 6, 2016, 15:21
Declan
I'm not sure what you mean by 'normalise' the errors, but if you want to compute mass flux at inlet you can run
postProcess -funcs '(flowRatePatch(name=inlet))’
Old   December 9, 2016, 09:58
Thomas A
Okay, so if the continuity error is a deviation between what comes into the system and what comes out, then by calculating the flux of the inlet, I should be able to find the global error in percentage by the following formula:
globalContErr/flux_inlet*100
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
