Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Regarding regIOobjectRead.C at line 73 error while converting results to paraview
Like Tree1Likes
  • 1 Post By hhh
Old   July 10, 2013, 07:14
Default Regarding regIOobjectRead.C at line 73 error while converting results to paraview
hhh
kunar
hhh is on a distinguished road
Greetings OF Friends,
I am using OF 2.2 and I run wingMotion tutorial in pimpleDyMFoam. It works fine. While converting results to paraview I type foamToVTK in terminal window, it shows error like this,
kumar@ubuntu:~/OF/kumar-2.2.0/run/tutorials/incompressible/pimpleDyMFoam/wingMotion$ foamToVTK
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.0-5be49240882f
Exec : foamToVTK
Date : Jul 10 2013
Time : 12:36:00
Host : "ubuntu"
PID : 4698
Case : /home/kumar/OF/kumar-2.2.0/run/tutorials/incompressible/pimpleDyMFoam/wingMotion
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/kumar/OF/kumar-2.2.0/run/tutorials/incompressible/pimpleDyMFoam/wingMotion/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Kindly help me about my quires.
Thanks for your valuable time
niran likes this.
kunar
hhh is offline   Reply With Quote
Old   July 10, 2013, 16:13
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi Kumar
is controlDict file there in the system folder or not?if not maybe you have forgotten about adding it to the system folder.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   July 10, 2013, 17:13
Retired Super Moderator
Bruno Santos
Greetings to all!
@Kumar:
How exactly did you run the tutorial? Because the answer is exactly in the step you didn't mention.
Edit the Allrun script with a text editor and you'll see every step well documented.
And if you look into the folder "wingMotion", you'll see 3 sub-case folders.
Now I'll leave it up to you to connect the dots
Best regards,
Bruno
Old   July 11, 2013, 01:57
hhh
kunar
Thanks for your reply immortality & wyldckat, Now its work fine I forgot to add the file
kunar
Old   November 24, 2016, 02:44
Default how to solve this
Niranjan Prabhu
niran is on a distinguished road
file: /home/user/OpenFOAM/user-2.4.0/run/waveFlume/constant/waveProperties at line 0.
FOAM exiting
i am new to openfoam someone can explain in detail
niran is offline   Reply With Quote
Old   November 24, 2016, 02:45
Niranjan Prabhu
FOAM exiting
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Import STAR-CD results -> Paraview BenBoo Siemens 7 March 29, 2012 05:02
ParaView installation problem on Suse 11.4 victorz OpenFOAM Installation 4 February 6, 2012 17:26
Peoblem with paraview on ubuntu 9.10 machine nabeels OpenFOAM Bugs 0 December 26, 2009 15:15
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
