April 11, 2013, 13:22 |
OpenFOAM sample utility
#1 | |
Rep Power: 13 |
could anybody give me an hint how to use sample utility correctly for all time steps? I only would like to sample Ux from the velocity field U. sampleDict-file Quote:
The help menu offers the option -time <range>. sample -time :0.1-1.5: (and similar versions) don't work. Aylalisa |
April 14, 2013, 13:45 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Aylalisa,
A few questions:
As for running for all time steps, I think is should be something like ("1.5" is the last time step): Code:
sample -time :1.5 Code:
sample -time 0: Bruno
April 16, 2013, 08:15 |
sample Ux
#3 | |
Rep Power: 13 |
Hello Bruno,
sample util works well if I sample U for all time steps or a range of time steps. All your recommended commands are fine. I am not able to extract only Ux of velocity field U. I have tried Ux, U(x), UX, U(1) and U.component(1) but do not receive the required result. OpenFOAM version 2.1.1 Do you know the solution for my problem? Thanks a lot! Best regards, Lisa Quote:
April 16, 2013, 10:31 |
Rep Power: 16 |
You have to create your components of the velocity vector before running sample utility with this command:
foamCalc components U This will create Ux, Uy, Uz folders in your time directories. After that you can run the sample utility |
August 22, 2019, 16:34 |
André Luiz Moura Silva Moreira
Rep Power: 11 |
I have tried this on OpenFOAM7, but without sucess.
But I did it as bellow: postProcess -func "components(U)" Then, next step on tutorial is execute the comand "sample", but I received: Command 'sample' not found, but can be installed with: sudo apt install barcode What I have to do? |
August 26, 2019, 16:47 |
Bruno Santos
Rep Power: 128 |
Quick answer: sample was replaced with using function objects only, namely you are meant to do a similar command to postProcess, but for sampling. See the OpenFOAM 7 User Guide, sub-section 2.2.3: https://cfd.direct/openfoam/user-gui...#x6-470002.2.3
Using probe function or sample utility on a patch | hfs | OpenFOAM Post-Processing | 1 | January 27, 2019 03:49 |
sample utility problem | And | OpenFOAM Post-Processing | 36 | May 20, 2014 08:50 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Understanding the coordinates of sample utility | vishwa | OpenFOAM Post-Processing | 4 | March 25, 2010 12:51 |
[Technical] Mathematical exact definition of mesh quality measures in OpenFOAM checkMesh utility | albcem | OpenFOAM Meshing & Mesh Conversion | 1 | October 31, 2008 04:12 |
