wallShearStress doesn't work in new solver (energy eq added in icoFoam) |
December 18, 2016, 09:31 |
Saurav Kumar
Rep Power: 9 |
i have added energy equation in icoFoam for heat transfer simulation and it is working fine but after simulation, in post processing i want wall shear stress and wall heat flux so i used wallShearStress and wallHeatFlux but i got some error Usage: icoTempFoam [OPTIONS] options: -case <dir> specify alternate case directory, default is the cwd -noFunctionObjects do not execute functionObjects -parallel run in parallel -roots <(dir1 .. dirN)> slave root directories for distributed running -srcDoc display source code in browser -doc display application documentation in browser -help print the usage Using: OpenFOAM-4.1 (see www.OpenFOAM.org) Build: 4.1 --> FOAM FATAL ERROR: Wrong number of arguments, expected 0 found 1 Invalid option: -postProcess Invalid option: -func FOAM exiting new solver name is icoTempFoam and i am using OF4.1. Thank you. Regards, Saurav |
IcoFoam stationary solution STRONGLY dependent on the tolerance of the linear solver | Mehrez | OpenFOAM Running, Solving & CFD | 1 | February 16, 2015 06:59 |
Turning of the energy solver at start | chris12345 | STAR-CCM+ | 0 | April 4, 2013 01:10 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
