Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Error requesting rho file while calculating Courant field - OF 2.4.0, sonicFoam
Old   June 1, 2018, 10:28
Default Error requesting rho file while calculating Courant field - OF 2.4.0, sonicFoam
Deep
deepbandivadekar is on a distinguished road
I have had to run my case in 2.4.0 instead of 5.0 because of version unavailability on this machine. The courant number is shooting up after some time and I'm trying to find out where by plotting Co field.
In 2.4.0, that's done by "Co" command after reconstructPar. When I run this, I get following error:
Time = 3e-08
    Reading phi
    Calculating compressible Co
    Reading rho
--> FOAM Warning :
--> FOAM FATAL IO ERROR:
cannot find file
file: /path/x_latest/case/3e-08/rho at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
This is repeated for each written time step. In the corresponding folders there's no rho file but Phi exists.
The description of this utility from the 2.4.0 user guide says Co is calculated based on Phi. So am a bit baffled at why this error about rho.
Can anyone direct me the right way?
deepbandivadekar is offline   Reply With Quote
courant number, openfoam 2.4.0, postprocessing, sonicfoam
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
