Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
PecletNo postprocessing function calculating the local Re?
Old   August 8, 2018, 04:37
Default PecletNo postprocessing function calculating the local Re?
Robert
RobertHB is on a distinguished road
Dear Foamers,
in trying to calculate the Peclet number for my simulation i stumbled across the PecletNo postprocessing function. Whose results are completely different from what i caluclated manually via Pe = U*L/D.
Doing a bit of reading in the source code and here in the forum i figured out that 1) the function uses nu instead of D and 2) uses the cell size. Since alot of the post where more than 5 year old, i wanted to ask:
Is it correct that the PecletNo function calculates the cell Reynolds number (Re = U*L/nu) instead of the Peclet number?
Basically, if this is true, the function is of no use to me, but what does one use the cell Reynolds number for? Figure out numberical instabilities? And where is the difference between the local Reynolds number and the cell Reynolds number?
Cheers,
Robert
RobertHB is offline   Reply With Quote
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
