[OpenFOAM] Integrating a parameter in openfoam/paraview, to find a 1-D equation from a 2D flow |
November 21, 2018, 19:23 |
mahdi
Rep Power: 12 |
Dear colleagues!
Consider a 2D, xy rotating mixer, which is used to disperse to liquids in each other. A simple shape is attached below. Obviously, the volume fraction of phases is a function of time, x and y. My data for validation is the side view of this mixer. Let's say the phase one is transparent. So, imaging is used to give the dispersion of phases in different horizontal lines. I want to integrate the alpha with respect to y, in order to achieve alpha=f(x) and report it automatically in each time step. The integration of paraview seems to perform int(int.dy)dx. What should I do? Thank you in advance! |
data analysis, integration, openfoam, paraview |
laminar and turbulent flow simulation in elbow fitting to find K values wtr Re | prashanth1234 | FLUENT | 4 | January 18, 2019 10:06 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
problem on energy and flow equation solving separately | preetam69 | FLUENT | 2 | July 30, 2013 21:08 |
Mass flow rate boundary condition for continuity equation for oscillating flow | p07ip705 | Main CFD Forum | 0 | February 28, 2013 01:33 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
