isoSurfaceCell (type surfaces) crash (interfoam) |
June 15, 2019, 09:08 |
#1 | |
Teresa
Rep Power: 10 |
Dear all,
I need some inspiration to conquer a post Process problem: Goal was to sample the interface (water/air). Output, as long as it's generated, looks pretty good, but the function stops with floating point eception: Quote:
At the end the goal is to wrtie out the interface much more often than the rest, but using postProcessing the calculation aborts.. wihtout it it's running. Code:
isoCell { type surfaces; libs ( "libsampling.so" ); writeControl adjustableRunTime; writeInterval 0.00001; surfaceFormat vtk; fields ( alpha.water U p_rgh ); interpolationScheme cellPointFace; surfaces ( interface { type isoSurfaceCell; isoField alpha.water; isoValue 0.5; interpolate true; } ); Regards, Teresa |
postprocess crash |
[Other] simulation of closing the gate using moving mesh | simin_ds | OpenFOAM Meshing & Mesh Conversion | 8 | April 12, 2019 05:49 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
multiphaseEulerFoam/tank discharge | ves | OpenFOAM Running, Solving & CFD | 8 | December 31, 2017 14:59 |
SimpleFoam - instable simulation | Specialist | OpenFOAM Running, Solving & CFD | 17 | August 12, 2014 04:52 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
